| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
Basic Hot Tub Wiring
by Expert Village
OK, here we're going to talk about the different wiring requirements for spas. Many spas, most common will be a two-forty volt, fifty amp dedicated circuit, which means that is it on its own breaker, it is a GFCI breaker which is for your safety and also... Read More »
Electrical Requirements When Powering a Chop Saw
by Expert Village
Hi! This is John from expertvillage.com. In this video clip, I will be discussing the electrical requirements for chop saws. This particular saw is wired at the factory for a standard 120 volt connection. You want to connect it to a 120 volt, 15 amp time... Read More »
Electrical Safety for Edge Sander
by Expert Village
Hi, this is Jon on behalf of Expert Village. In this video clip I will be talking about electrical safety. This particular sanding machine is 220 volts meaning it requires a lot more voltage than your typical outlet that you would have in your house... Read More »
Checking Voltages on Vintage Radios
by Expert Village
Hi I'm Larin Parker with Expert Village and I'm going to show you how to check voltages. This is another great way to diagnose things when you have no idea, what's going on. You turn it on and you get no result. We are looking at the back of this radio... Read More »
How to Run Vehicle Diagnostic Testing
by Expert Village
Hello my name is Mark Blocker with Expert Village. In this segment we are going to cover the diagnostic testing of automobile fuse system. Before we begin the test we need to know what circuit we're having a problem on. For example, if it's a wiper... Read More »
