Old 10-27-2012, 09:07 AM   #1
melanie61704's Avatar
outlet sparked
turned off power to outlet cut out damaged drywall around it then turned it back on with nothing pluged into it this morning i made pot of coffee in a different outlet on same line and later when i came back the power was out in the outlet I went to basement reset breaker went upstairs fliped the light switch and saw the outlet spark...turned breaker off, what is my next step to fix this?
melanie61704 is offline   Reply With Quote
Old 10-27-2012, 10:23 AM   #2
DIY Enthusiast
sublime2's Avatar
outlet sparked
Replace the receptacle.
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
melanie61704 (10-27-2012)
Old 10-27-2012, 10:24 AM   #3
Master Electrician
outlet sparked
You probably nicked the wire when you cut the drywall
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
The Following User Says Thank You to andrew79 For This Useful Post:
Old 10-27-2012, 10:03 PM   #4
outlet sparked
Originally Posted by melanie61704 View Post
turned off power to outlet cut out damaged drywall around it then turned it back on with nothing pluged into it this morning i made pot of coffee in a different outlet on same line and later when i came back the power was out in the outlet I went to basement reset breaker went upstairs flipped the light switch and saw the outlet spark...turned breaker off, what is my next step to fix this?
Which outlet?
Which outlet?
The circuit wires daisy chain from one receptacle/switch box to the next. There was probably a loose connection in the box where you saw the spark.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
AllanJ is online now   Reply With Quote
The Following 2 Users Say Thank You to AllanJ For This Useful Post:
melanie61704 (10-28-2012), sublime2 (10-27-2012)
Old 10-28-2012, 06:02 PM   #5
outlet sparked
Originally Posted by AllanJ
Which outlet?
Which outlet?
That was it. A loose connection ty
Help rewiring 220V 3-prong outlet to 4-prong grounded outlet madmaxwell Electrical 7 03-23-2012 07:37 AM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 10:13 PM
Switched Outlet Issue mjm Electrical 11 01-23-2011 08:41 AM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
