Outlet Spark - Electrical - DIY Chatroom Home Improvement Forum
Old 01-24-2010, 06:12 PM   #1
outlet spark
Occasionally when I plug a three pronged plug into an outlet, there is a blue spark. The outlet seems to be correctly installed. What should I do? Is this a fire hazard?
picsaro is offline   Reply With Quote
Old 01-24-2010, 06:21 PM   #2
firehawkmph's Avatar
Rewards Points: 1,884
Pic,
Is whatever you are plugging in 'on'? That will cause a spark as you complete the circuit. If that's not the case, the outlet and the wiring to it should be checked.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Outlet Spark DIYLI Electrical 13 06-16-2012 09:08 AM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
outlet made a pop, spark, tripped breaker-need to fix louisemr Electrical 1 06-13-2007 07:58 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
