Outlet Spark - Electrical - DIY Chatroom Home Improvement Forum
Old 03-29-2008, 09:42 PM   #1
Outlet Spark
I noticed my wall outlet spark when I plug in my laptop's power supply. No breaker tripped. The outlet does not spark when other items are plugged in. Most are 2 prong, the laptop power supply is 3 prong. The TV experiences interference when the power supply is plugged in. Is all this a normal condition?
DIYLI is offline   Reply With Quote
Old 03-29-2008, 09:57 PM   #2
Rewards Points: 150
1st,
Did you consider removing the receptacle and checking it, and also if the conductors are firmly attached to it. If there are additional connections in the the box (wire-nutted) .. check them out too.
JGarth is offline   Reply With Quote
Old 03-29-2008, 10:18 PM   #3
Rewards Points: 266
Are we talking the about the little spark that occurs when the prongs are inserted into the receptacle's contacts? If so, this is normal. The adapter contains either a transformer or solid state power supply, and it does draw some current when it is in use / plugged in.
Not sure about the interference problem.
junkcollector is offline   Reply With Quote
Old 03-29-2008, 10:26 PM   #4
Union Electrician
goose134's Avatar
As stated before, the small spark is normal. Try plugging it in to various outlets around the house to satisfy yourself.
As for the interference, I've never run into this with a laptop, but other devices have created interference on affiliated circuits. Try plugging a cordless tool charger and a radio into the same circuit. Tremendous static.
It may have something to do with the transmodal potentiometer. It is a device that clips the waveform on the fifth and seventh hamonic. Unfortunately this is often the same waveform that many variable frequency infindibulators use on household televisions.
goose134 is offline   Reply With Quote
Old 03-29-2008, 10:29 PM   #5
Thanks to all for the quick reply. It's a little spark that occurs when the prongs are inserted into the receptacle's contacts. Sounds like its normal. The interference could be because the TV outlet is in line with this other outlet.
Old 03-30-2008, 12:43 PM   #6
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
Yeah, what he said.
jrclen is offline   Reply With Quote
Old 03-30-2008, 03:07 PM   #7
Idiot Emeritus
Rewards Points: 1,492
Most of these power supplies are called 'switching' supplies. They basically apply line voltage to the output and switch it off very quickly when the desired voltage is reached. This type of operation tends to distort the waveform of the incoming line. (Harmonics).
To minimize this effect, a capacitor is placed across the input. When initially energized (plugged in) a capacitor is basically a dead short. This causes a huge inrush of current for a VERY short time. Thus the spark.
Rob
micromind is offline   Reply With Quote
Old 06-15-2012, 09:42 PM   #8
Laptop plug
I get the same small spark when I plug my laptop in, but only when the power cord is attached to the computer. When I plug the cord in first, no spark.
Duchess576 is offline   Reply With Quote
The Following User Says Thank You to Duchess576 For This Useful Post:
Thurman (06-16-2012)
Old 06-16-2012, 08:29 AM   #9
Rewards Points: 776
I didn't know it was April 1st.
As said by other all these power supplies are switching. They are regulated by standards to limit their interference, both radiated (through the air) and conducted (through wires). That said they still emit interference.
If you plug into to a different branch circuit that should help and just separate the distance. Digital TV should be pretty immune to this type of noise however, are you still on analog? Maybe your TV has a poor power supply filter in it and cheap terminal strip from Radioshack (with an EMI filter in it) would help. Don't plug laptop into this same power strip, just TV.
curiousB is offline   Reply With Quote
Old 06-16-2012, 09:00 AM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,822
Thank you for sharing with us that you are having the same issues as the OP was having four years ago.
The replies to him would now apply to you. Even four years later.
Speedy Petey is online now   Reply With Quote
Old 06-16-2012, 09:08 AM   #11
Code05's Avatar
Rewards Points: 1,104
Thanks, I did not notice and was going to reply. Why do they not close old threads here?
Code05 is offline   Reply With Quote
Old 06-16-2012, 09:45 AM   #12
Usually it's not an issue, and many times someone has the same situation and wants more info on it or has questions about some of the replies.
Then other times someone will come along and dig up and ancient (4 year old) thread just to say "The same thing happened to me".
Old 06-16-2012, 10:05 AM   #13
Code05's Avatar
I suppose so, but I would prefer something like this:
"In regards to this thread, (insert link), I have a question about ......"
It makes threads much clearer JMHO.
Old 06-16-2012, 10:08 AM   #14
Oh, don't get me wrong, I completely agree.
If the software were mine to tweak I'd put a 6 month "no activity" limit on threads and then they'd auto close.
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
outlet made a pop, spark, tripped breaker-need to fix louisemr Electrical 1 06-13-2007 08:58 PM
20a Outlet Vs. 15a Outlet bobo Electrical 3 05-29-2006 11:55 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
