Outlet Shorts When Secured In Box, But Not When Dangling!!! - Electrical - DIY Chatroom Home Improvement Forum
Old 05-28-2012, 01:27 PM   #1
outlet shorts when secured in box, but not when dangling!!!
So i have space in a weird building of art studios. the building is old, and a lot of different people have done a lot of weird wiring around here. that being said i try to make any wiring i do as safe as possible.
so i had this busted ceiling fan/ light controlled by a switch. the fan didn't work so i wanted to replace it. so i took the romex coming from the ceiling (used to go into the fan) into a 4" utility box. i had it branch off in two directions with MC. one about a foot away to a small utility box that can hold one set of 2 outlets.
another goes down to a switch, which then goes to a string of lights.
everything seemed to be wired ok when i tested it. i left the outlet dangling out of the box and plugged a light into it leaving the switch that controlled the separate string of lights off.
when i flicked the main switch the light plugged into the outlet came on. when i flipped the other switch the string of lights came on.
so i then turned everything off and secured everything into the boxes with covers. and did the same test. this time the outlet worked fine, but when i flipped the second string of lights on it tripped the breaker. when i let the outlet dangle outside of the box its fine, but as soon as the metal brackets on the outlet touch the box it shorts.
anyone have any idea what the problem is?
Thanks,
kingmob37 is offline   Reply With Quote
Old 05-28-2012, 01:32 PM   #2
Licensed electrician
Rewards Points: 1,472
You have a hot wire touching a grounded surface when it is installed in the box. Look for burn marks to narrow down your search.
plummen (05-28-2012)
Old 05-28-2012, 01:37 PM   #3
but why does it only short when the other switch is flipped? if it's in the outlet box shouldn't it short when the power it turned on to that outlet? the switch to the sting of lights works fine as long as the outlet is not secured to the box.
Old 05-28-2012, 02:25 PM   #4
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
If you are using a metal box then one of the screws or wires is touching the metal box. You should also have the metal box bonded to your ground wire.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 05-28-2012, 02:31 PM   #5
kevinp22's Avatar
the fact that is trips when the one switch is turned on helps you narrow down which wire(s) are shorting - check all connections on the hot side controlled by that switch
kevinp22 is offline   Reply With Quote
Old 05-28-2012, 02:34 PM   #6
joed's Avatar
Rewards Points: 12,362
Tell us how you connected the wires. You could have the wrong wires connected to the ground screw somewhere.
Old 05-28-2012, 02:36 PM   #7
but that switch only causes a short if the outlet is not secured. i can't find anywhere that the hot could be touching the metal in the box. the problem has to be in the outlet box right?
Old 05-28-2012, 02:48 PM   #8
rrolleston's Avatar
When it's in the box and attached check that no screws are touching the metal box. And also wrap tape around the receptacle so it covers all screw heads with a couple layers of tape.
Old 05-28-2012, 03:23 PM   #9
There may be a hot wire exposed in the box that hits the receptacle that is grounded.
Old 05-28-2012, 07:47 PM   #10
Sparky
Rewards Points: 510
Or the box is energized when the lights are on, and the ground is only landed on the receptacle
Techy is offline   Reply With Quote
Old 05-28-2012, 08:50 PM   #11
Rewards Points: 794
If the metal box has built in metallic cable clamps next to the wire knockout. If you tighten these too tight they can bite through the romex jacket and wire insulation and pinch the (hot) wire to ground, causing a short. It could be intermittent based on strain of wires. Try loosening off the clamp as a experiment.
curiousB is offline   Reply With Quote
Switched Outlet Issue mjm Electrical 13 06-14-2015 07:56 PM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
