Outlet Shorted But Breaker Did Not Trip - Electrical - DIY Chatroom Home Improvement Forum
Old 06-03-2010, 10:06 AM   #1
outlet shorted but breaker did not trip
I was awoken the other night by the sound of an outlet shorting (throwing sparks and filling my house with smoke). my first reaction was to kill the power to the house. after i did that, i checked the breakers to see where exactly the short had happened, but none of the breakers were tripped. The outlet that shorted was for my washer, it is the only receptacle on that wall, and has its own dedicated breaker. The receptacle and the plug were both completely destroyed.(all metal parts were found as small balls of metal). Why would the breaker not trip during such a violent short?
crees4 is offline   Reply With Quote
Old 06-03-2010, 10:16 AM   #2
Two possibilities one, a defective breaker and two, although it drew enough current to over heat the outlet it wasn't enough current to trip the breaker.
hayewe farm is offline   Reply With Quote
Old 06-03-2010, 10:17 AM   #3
Rewards Points: 160
I am not certain but I would replace the fried parts and get a new breaker.
Old 06-03-2010, 10:38 AM   #4
Check the washing machine by plugging it into another known-good outlet.
Ditto for #2; apparently your outlet acted as a fuse and so kept the breaker from tripping.
You can also check the breaker if you have its trip curve from the Web, but I would do as #3 suggested.
Old 06-03-2010, 11:32 AM   #5
Where are you located ?
What is the MFg of the breaker panel ?
Old 06-03-2010, 01:22 PM   #6
Rewards Points: 502
was it a 20 amp breaker and a 15 amp outlet?
I've found all sort of broken outlets. it would be easy for a small section of metal to short and heat up, but have enough resistance to keep from tripping, could also be a breaker problem.
forresth is offline   Reply With Quote
Old 06-04-2010, 10:18 AM   #7
I=E/R
a7ecorsair's Avatar
Just because there were sparks and smoke, it doesn't mean there was a short. This is a good example as to why Arc Fault breakers are now required in new construction.
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
DangerMouse (06-04-2010)
Old 06-04-2010, 10:54 AM   #8
Rewards Points: 160
Excellent post. You are correct. Breakers see overload and short circuits only. If the wires on the receptacle were loose and resulted in a high resistance connection, it would behave exactly like the OP's did.
The Following User Says Thank You to J. V. For This Useful Post:
Old 06-04-2010, 11:45 AM   #9
So with arc fault devices keeping watch, maybe the outlet manufs can relax their quality control standards
http://en.wikipedia.org/wiki/Moral_hazard
Old 06-04-2010, 08:03 PM   #10
I=E/R
a7ecorsair's Avatar
The outlet manufacturers
How about those that don't throw away a frayed extension cord, do their own wiring and try to get two wires under one screw, step on plugs and then try and bend thing back to where they belong, try and fix an old lamp that needs a rebuild with a complete new cord, or don't do a correct job when installing a wire nut?
Old 06-04-2010, 10:26 PM   #11
Was it a Federal Pacific Stab-Lok panel? Or a Zinsco, or Sylvania Panel? They have a history for malfunctioning breakers and should be replaced.
altow90 is offline   Reply With Quote
Old 06-05-2010, 08:54 AM   #12
They get Darwin Awards.
Drilled through 12/3 and breaker didn't trip vseven Electrical 12 04-11-2010 11:03 AM
A hot wire buried in the yard that you cannot even trip a breaker by sharting it? BJLower Electrical 3 01-21-2010 02:24 PM
Replaced Outlet, but now tripping the circuit breaker bman598 Electrical 9 05-21-2009 07:35 PM
Sq D Trillaint Breaker problem jmreynol Electrical 3 04-28-2009 07:06 PM
Multiple Circuits - Same Outlet box Revnjeff Electrical 2 09-04-2008 08:17 PM
