Outlet Screws? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-14-2015, 11:14 AM   #1
Rewards Points: 290
Outlet screws?
Is it okay to take an outlet screw fully out so to get the wire loop on easier?
Mikeron is offline   Reply With Quote
Old 08-14-2015, 11:46 AM   #2
Rewards Points: 5,336
There's usually a stop like feel at the end of the screw. You can force it out of the threads if you continue to unscrew it. It's also hard to reinsert the screw into the threads. If the loop is properly open and in the same plane, you shouldn't have a problem getting it around the screw. Make sure the loop goes around the screw in a clockwise position. If you do it the other way it will open as you tighten it.
Ron
B. Franklin 1759
The Following User Says Thank You to Ron6519 For This Useful Post:
Mikeron (08-14-2015)
Old 08-14-2015, 12:23 PM   #3
Licensed electrician
Rewards Points: 1,864
N there should be no need to back the screw out entirely .
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
Mikeron (08-14-2015), Speedy Petey (08-14-2015)
Old 08-14-2015, 12:54 PM   #4
Special User
Rewards Points: 1,230
I've done this a few times. The trick is, as you unscrew and it stops, screw it back in a bit, then out a bit more, then in a bit, then out a bit more, etc. There is a deliberate burr on the screw threads and working it in and out repeatedly straightens out the burr.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
The Following 2 Users Say Thank You to tylernt For This Useful Post:
Mikeron (08-14-2015), rjniles (08-14-2015)
Old 08-14-2015, 02:14 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,252
Why would you do that. The loop fits fine under the screw without it.
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
Old 08-14-2015, 02:26 PM   #6
joed's Avatar
Rewards Points: 13,696
If you have to remove the screw to get the wire on then you are either
1. doing it wrong.
2. using too large a gauge wire for the device.
3. trying to put two wires under one screw which is not allowed.
The Following User Says Thank You to joed For This Useful Post:
Pharon (08-14-2015)
Old 08-14-2015, 02:59 PM   #7
Special User
The main reason is too-short conductors in an old-work scenario. I dunno when the 6" free length rule was adopted, or maybe it wasn't enforced, but I often open up a JB and there's only enough free length to hook the first wire on, then the receptacle is held so close to the JB you don't have enough slack to move it around and hook any other wires on.
I understand that I could pigtail, but even though I realize that pigtails don't count in NEC boxfill calculations, there is a practical consideration that on those little metal boxes -- there's no way you're going to fit two cables and a receptacle and a bunch of pigtails without really bending and jamming those wires in there, risking breaking old brittle insulation. Or breaking the stressed conductors themselves.
I suppose I could wrap the old conductors in electrical tape to protect them, but then I'd need to buy white tape for the neutrals and well, I just don't think it would look too professional. But removing the screws from the new receptacle and then feeding the screws through the wire loops lets the box stay emptier without stressing anything.
Now that I think about it though, those push-on Wagos would probably be a nice solution for pigtailing in this scenario. But more $$$.
Old 08-14-2015, 03:33 PM   #8
Buy back wired devices.
The Following 5 Users Say Thank You to Jim Port For This Useful Post:
Msradell (08-14-2015), Oso954 (08-14-2015), rjniles (08-14-2015), sgip2000 (08-14-2015), tylernt (08-14-2015)
Old 08-14-2015, 04:04 PM   #9
A "Handy Husband"
rjniles's Avatar
That's all I use.
Oso954 (08-14-2015)
Old 08-14-2015, 04:18 PM   #10
Rewards Points: 744
that the same as back-stab / push-fit connectors?
Seattle2k is offline   Reply With Quote
Old 08-14-2015, 04:19 PM   #11
Special User
Nope. Back-stabs depend on a little spring. Back-wire connections are a compression connection that clamp down on the wire with a screwdriver. Very solid, much stronger.
Old 08-14-2015, 04:26 PM   #12
Oso954's Avatar
Rewards Points: 1,610
That's all I use.
+1
Not just because of the back wire, but because they are commercial grade.
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
Bathroom GFCI Outlet trouble RyG1357 Electrical 3 08-20-2011 03:40 PM
Drywall nail types kevsprojects Drywall & Plaster 23 07-31-2011 07:34 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
