Outlet Rules For An Unfinished Room In A Finish Basement - Electrical - DIY Chatroom Home Improvement Forum
Old 01-17-2011, 12:12 PM   #1
Outlet rules for an unfinished room in a finish basement
I know the NEC has different rules for finished vs unfinished basements but about an unfinished room (like laundry or storage) in a finished basement. Does it follow the unfinished or finished rules? I'm specifically curious about a storage room that will have an insulated exterior wall but bare studs and joists with a vinyl floor. Do I need just one GFCI outlet or do I used non-GFCI every 12 feet?
Thanks in advance!
frizbplaya is offline   Reply With Quote
Old 01-17-2011, 12:49 PM   #2
Licensed electrician
Rewards Points: 1,752
The receptacles in the unfinished part require GFI protection, but you do not need to follow the 6/12 spacing requirements.
Small basement room moisture ? timrec Building & Construction 2 08-25-2010 05:14 AM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Should I put 2x6 or 2x10 above garage if I plan to finish the room in the future? rockne Building & Construction 35 06-08-2009 09:33 PM
Noob question for basement finish electrical dtmbizzle Electrical 16 07-11-2007 07:08 AM
Want to finish basement mopared Remodeling 3 02-20-2005 04:49 AM
