Old 11-11-2012, 11:37 PM   #1
Outlet quit working
The outlet quit working all of a sudden. I pulled it out of the wall and found about 75V between hot and neutral and 118V between hot and ground. How does a neutral suddenly go "bad". The house is about 25 years old and no aluminum wire.
glkd is offline   Reply With Quote
Old 11-12-2012, 12:00 AM   #2
Licensed Electrician
k_buz's Avatar
Outlet quit working
Sounds like a classic backstab failure situation to me. Turn off the breaker that controls this receptacle, the start removing other receptacles that are out looking for a loose neutral. I suspect it will come completely out of the receptacle when you remove it from the box.
Location...Location...Location
k_buz is online now   Reply With Quote
outlet not working rodneybarkhouse Electrical 2 08-05-2011 06:30 PM
Half of outlet stop working! WHY?? drad88 Electrical 5 06-23-2011 12:36 PM
120V outlet not working wsdivall Electrical 7 06-18-2011 10:29 PM
Outlet stopped working repeatedly Mebbid Electrical 3 04-25-2011 09:06 AM
Outside outlet stopped working mclontz Electrical 13 12-11-2008 10:37 AM
