Outlet Pulling Away From The Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 08-18-2009, 11:23 PM   #1
Rewards Points: 674
Outlet pulling away from the wall
If I push the wall anchors on the back of this outlet back into the holes they were in, is there something I can use to keep them from falling back out?
Thanks.
gma2rjc is offline   Reply With Quote
Old 08-18-2009, 11:26 PM   #2
BCSparkyGirl's Avatar
not that I have found. Usually gotta redo it if I f**k it up. If anyone knows a trick, i would be interested in knowing too......
BCSparkyGirl is offline   Reply With Quote
Old 08-19-2009, 04:12 AM   #3
Household Handyman
Rewards Points: 1,408
IMO-that box definitely needs to be re-anchored. It appears that the plastic anchors did not get spread enough by the screws put into them to be secure. Just my 2 cents worth on this, David
Old 08-19-2009, 05:50 AM   #4
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Thanks.
gma, The EMT may be misaligned or more likely is not properly secured to the Wall above the offset visible in your photo.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-19-2009, 07:31 AM   #5
Rewards Points: 1,536
To withstand the force of plugs being removed, the outlet box needs to be (itself) firmly anchored to the wall.
Exactly what size plastic anchors and what size screws to use is mostly trial and error.
Masonry screws usually work better than regular screws plus plastic anchors.
Old 08-19-2009, 07:50 AM   #6
Rewards Points: 674
You're right about the anchors. It doesn't look like they opened at all. I'll get those replaced. New holes will probably have to be drilled since the holes that are there right now are pretty big.
Being that I have no experience with electrical work, is this something I can do myself, or should I hire someone? It seems like the box has to be opened to replace these.
You hit it right on the head Bob. There isn't an EMT securing it to the wall. It doesn't look like there ever was one as there are no holes drilled in the wall except where the box sits. The pipe with the wire in it hangs loose when the box falls down. I should be able to put one of those on. Maybe one at the top of the pipe and one above the box?
Old 08-19-2009, 07:56 AM   #7
joed's Avatar
Rewards Points: 13,308
Turn off power to receptacle and remove receptacle from box. Probably could leave wires attached. Push box back against wall and anchor using masonary screws.
Old 08-19-2009, 02:17 PM   #8
Tool Geek
PaliBob's Avatar
gma, The "pipe" is EMT (Electrical Metallic Tubing)
To expand on joed's directions to get the Outlet back against the wall:
  1. Turn off Circuit Breaker, that powers the Outlet, OFF
  2. Remove the Outlet Cover plate
  3. Remove the two screws that hold in the Outlet (the Receptacle)
  4. Gently pull the receptacle as far Out and Up as possible
  5. Remove the two old mounting Screws and Anchors from the box.
Take the anchors down to the Hardware store and get two anchors the next size Larger diameter, Also two new Larger Metal Screws.
  • Verify that the new anchors will fit tightly in the existing holes
  • Verify the new screws will fit the holes in the box, If not drill out the box.
  • Mount the Box with the new Anchors and Screws
  • Reverse steps 4,3,2,1
If you have access to a hammer drill you can EMT straps. They should be at least every 3ft.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-19-2009, 02:33 PM   #9
Rewards Points: 674
Thank you Bob. I appreciate the detailed explanation. That helps a lot!
I'll run to the store and get the parts this evening so I can get that fixed.
If I don't have a hammer drill, can I use a drill bit meant for drilling cement and my electric drill?
Thanks again for your help.
Old 08-19-2009, 03:36 PM   #10
Liquid nails or epoxy will work without taking anything apart..
I would simply take the recep out and re anchor it properly.
220/221 is offline   Reply With Quote
Old 08-19-2009, 06:14 PM   #11
Tool Geek
PaliBob's Avatar
....can I use a drill bit meant for drilling cement and my electric drill?.......
probably, if you use enough pressure. Get the masonry bit and try it. I was going to suggest renting one from HD, but when I called, they quoted $40/day.
If you lived near me, I'd let you use one of mine. I have four.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 08-19-2009, 06:48 PM   #12
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
This adhesive works really well for things like this:
http://www.stickwithpl.com/Products....9-a343f2ef9458
give it a day to cure. It will cost about $5 and you will be done in 5 minutes.
Jamie
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 08-19-2009, 07:12 PM   #13
Rewards Points: 674
I have a tube of that PL Premium construction adhesive that's already open. Maybe I'll give that a try first and still add some of the EMT straps.
$40 a day to rent a hammer drill? Thanks for checking into that for me. I guess it would be worth it if you had a full day of drilling to do.
Old 08-20-2009, 06:50 AM   #14
Bigplanz's Avatar
Rewards Points: 990
I've had this problem a couple of time: anchors strip out a hole that crumbles, won't hold them in, etc. One cheap, fast fix is wrap electrical tape around the anchor (thus making it thicker) and putting it in the hole. (Make sure it's snug; you might have to tap it in with a hammer). Once the anchor is reset, use a screw one size larger than the one that was in it (Instead of an 8, use a 10). The thicker anchor and the bigger screw will compress the anchor firmly in the hole, thus securing the box to the wall.
This works every time (or at least has for me, YMMV)
In re: hammer drills. This is a great thing to have: makes lots of noise, sends dust flying everywhere and drills holes in concrete. For light duty applications (like in the home, where it might be used as a hammer drill maybe five times a year) just go buy a cheap one from Big Lots or Harbor Freight Tools. I got mine for $28 at Harbor Freight a couple of years ago and works fine.
Bigplanz is offline   Reply With Quote
Old 08-20-2009, 07:06 AM   #15
Tool Geek
PaliBob's Avatar
I have a tube of that PL Premium construction adhesive that's already open. Maybe I'll give that a try first and still add some of the EMT straps..........
If you don't first remove the screws and anchors, when you push the box back against the wall, the the attached screws may push back inside the box and short something out.
Disclaimer
& Stay Safe
.....Bob Lavery
Considerations when pouring concrete against a stucco wall? clint_nichols Building & Construction 9 09-24-2009 05:28 AM
Range outlet pushes oven too far from wall givemeabreak Electrical 8 08-19-2008 12:14 AM
Strange problem w. wall outlet, please help! yiplong Electrical 15 07-22-2008 04:02 AM
This is not a load-bearing wall, right? AllGoNoShow Building & Construction 4 01-07-2007 03:49 PM
Pulling romex thru wall with old romex? Doug Crf Electrical 4 04-11-2006 09:33 AM
