Old 05-18-2009, 02:39 PM   #1
Angry
outlet problem
installed a new leviton triplex outlet on one side of my kitchen(works great).installed one on other side which didn't work.i re-installed old outlet
and now it doesn't work either
wright.hamilton is offline   Reply With Quote
Old 05-18-2009, 03:41 PM   #2
outlet problem
1.You might have tripped the GFCI recep.
Possibly by using a tester hot to ground????
2. You might have a bad connection in the second one you installed (it may feed the first one)
220/221 is offline   Reply With Quote
Old 05-18-2009, 03:46 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
outlet problem
+1
Old 05-18-2009, 04:08 PM   #4
It was a dark and stormy
Yoyizit's Avatar
outlet problem
A tripped GFCI will open the hot and neutral lead of downstream outlets.
To check for both being open you need a known good hot connection [supposed to be the short slot of an outlet] and a known good neutral/ground [outlet long slot or round hole] and a lamp and Alligator Clip Leads.
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 03:44 PM
Adding Ceiling Light From Switched Outlet vboz5 General Discussion 2 03-04-2009 01:53 PM
loose outlet boxes on metal studs windowguy Electrical 7 01-29-2009 01:12 PM
20a Outlet Vs. 15a Outlet bobo Electrical 3 05-29-2006 11:55 PM
Adding garage outlet Shane Electrical 1 02-23-2006 05:43 PM
