-   -   outlet problem (http://www.diychatroom.com/f18/outlet-problem-44709/)
wright.hamilton 05-18-2009 01:39 PM
outlet problem
installed a new leviton triplex outlet on one side of my kitchen(works great).installed one on other side which didn't work.i re-installed old outlet
and now it doesn't work either
220/221 05-18-2009 02:41 PM
1.You might have tripped the GFCI recep.
Possibly by using a tester hot to ground????
2. You might have a bad connection in the second one you installed (it may feed the first one)
Speedy Petey 05-18-2009 02:46 PM
+1 :thumbsup:
Yoyizit 05-18-2009 03:08 PM
A tripped GFCI will open the hot and neutral lead of downstream outlets.
To check for both being open you need a known good hot connection [supposed to be the short slot of an outlet] and a known good neutral/ground [outlet long slot or round hole] and a lamp and Alligator Clip Leads.
