Outlet Problem - Electrical - DIY Chatroom Home Improvement Forum
Old 12-02-2008, 08:14 PM   #1
Question
outlet problem
I was wondering if anyone knew what is wrong here . I have 4 outlets on a circuit when I check voltage on any of the 4 I get 120 volts but if I plug anything in it will not work any help would be nice.
coalman is offline   Reply With Quote
Old 12-02-2008, 08:23 PM   #2
Rewards Points: 150
Did they work previously? How are you checking?
Gary
Gary_602z is offline   Reply With Quote
Old 12-02-2008, 08:30 PM   #3
unsure of previous condition but i checked with both an analog and a digital meter all seem to be wired corectly and all have full voltage but still will not work
Old 12-02-2008, 08:47 PM   #4
I assume you are testing hot to neutral.
That's why I always start troubleshooting with a resistive meter like a wiggy. It puts a small load on the circuit and you can feel some problems.
Picture a wire that is only making contact by a thread. It will still read 120V on a digital meter but a load can't get thru that thread sized wire.
Pull the receps out and you will find a bad connection in the back of the first one that is not working or the last one that is working.
220/221 is offline   Reply With Quote
Old 12-02-2008, 09:02 PM   #5
the supply line goes to a junction box with a terminal block and each outlet is on its own wiring . I checked the junction box,each outlet and the breakerbox but found no loose or bad wires
Old 12-03-2008, 12:35 AM   #6
Rewards Points: 508
Send a message via AIM to theatretch85
Terminal Block? Last time I saw one of those in a box was a picture of wiring from the UK. Where are you located?
theatretch85 is offline   Reply With Quote
Strange problem w. wall outlet, please help! yiplong Electrical 15 07-22-2008 04:02 AM
Outlet Problem!!! jlenigk17 Electrical 6 08-03-2007 04:09 AM
electrical outlet problem ? BEN17 Electrical 1 07-29-2007 06:23 PM
Electrical Outlet Problem McRier Electrical 3 12-19-2005 12:33 PM
Need opinions on fixing an outlet problem ryaniniowa Electrical 4 03-20-2005 09:06 PM
