-   -   outlet problem (http://www.diychatroom.com/f18/outlet-problem-33051/)
coalman 12-02-2008 08:14 PM
outlet problem
I was wondering if anyone knew what is wrong here . I have 4 outlets on a circuit when I check voltage on any of the 4 I get 120 volts but if I plug anything in it will not work any help would be nice.
Gary_602z 12-02-2008 08:23 PM
Did they work previously? How are you checking?
Gary
coalman 12-02-2008 08:30 PM
unsure of previous condition but i checked with both an analog and a digital meter all seem to be wired corectly and all have full voltage but still will not work
220/221 12-02-2008 08:47 PM
I assume you are testing hot to neutral.
That's why I always start troubleshooting with a resistive meter like a wiggy. It puts a small load on the circuit and you can feel some problems.
Picture a wire that is only making contact by a thread. It will still read 120V on a digital meter but a load can't get thru that thread sized wire.
Pull the receps out and you will find a bad connection in the back of the first one that is not working or the last one that is working.
coalman 12-02-2008 09:02 PM
the supply line goes to a junction box with a terminal block and each outlet is on its own wiring . I checked the junction box,each outlet and the breakerbox but found no loose or bad wires
theatretch85 12-03-2008 12:35 AM
Terminal Block? Last time I saw one of those in a box was a picture of wiring from the UK. Where are you located?
