Old 07-23-2011, 09:12 PM   #1
outlet problem
the outlets in both my bathrooms are not working. The outside outlets that are on the same GFCI breaker are working. I have tested the gfci breaker and reset it but the the outlets will not work. Can only part of a GFCI breaker be bad.
bobzam is offline   Reply With Quote
Old 07-23-2011, 09:31 PM   #2
Electrician
SD515's Avatar
outlet problem
If the outside receptacles are working, then the problem isn’t the breaker, if they truly are on the same circuit. You probably have a loose/broken connection, either at one of the outside recepts, or one of the bath recepts, or a broken wire in between.
Turn off the breaker and check the connections at the receptacles.
Also, consider running a new circuit to either the baths or the outside recepts. Bath receptacles aren’t supposed to be shared with other receptacles.
Kyle
Old 07-23-2011, 09:41 PM   #3
outlet problem
I assum they are on the same GFCI. There is only one GFCI in box and it is marked bathroom outlets. I know it also is on the outside outlets becasue when I shut it off the outside outlets do not work. Also the light in the bathroom are on it and they are not working.
Old 07-23-2011, 09:46 PM   #4
outlet problem
I know they are on the same breaker becasue when I cut it off the outside outlets do not work. The GFCI breaker is marked bathroom outlets/light. And the light do not work also. Everything was working fine no problems. I turned on the switch for the light heard a pop and that was when the problem started.
Old 07-23-2011, 09:57 PM   #5
Electrician
SD515's Avatar
outlet problem
I assume you have regular receptacles in the bathroom and not GFI’s since you have a GFI breaker.
Do you have an idea where the ‘pop’ came from? That’ll be the place to start looking. Might be in the switch box or receptacle(s) box, or even in the light.
Another note, since you reset the breaker and it’s staying on, I’d bet a wire came disconnected or burnt in half or something like that. If it was a ‘dead short’, the breaker wouldn’t reset.
Kyle
Old 07-23-2011, 10:19 PM   #6
outlet problem
the pop came from the light switch.
Old 07-23-2011, 10:27 PM   #7
Electrician
SD515's Avatar
outlet problem
Time to take the switch out and see what happened. Power off of course.
Kyle
Converting switched outlet to unswitched.. Blivit Electrical 8 07-11-2011 08:07 AM
Changing 2 way switch to control light, not outlet? andysam Electrical 0 05-30-2011 10:20 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 09:38 PM
outlet problem hokie_engineer Electrical 13 03-18-2010 04:55 PM
