-   -   Outlet Problem!!! (http://www.diychatroom.com/f18/outlet-problem-10305/)
jlenigk17 07-30-2007 10:09 PM
Outlet Problem!!!
Hi all,
I'm new, and just moved into my own place. I bought a decent computer and was told a UPS (Uninterrupted Power Source) was a good idea to keep my comp in tip top condition. My problem is that the plug is straight and not a 90 degree one. So with the weight of the heavy cord and occational bumping of the plug it tends to want to come out and unplug itself. Since i have important equipment on this UPS i'm trying to find a solution to keep this plug in. Does anyone know if there is a lock or harness that can keep my plug secure, or if it is kosher to use an extension cord... Anything will help at this point. Thanks all in advance.
DIYer
hbsparky 07-30-2007 10:37 PM
sounds like you should just replace the recepticle, sounds like the wipers are worn and it's time for a replacement.
Dansbell 07-30-2007 11:19 PM
You may very well need a new receptacle, however I have a similar problem with those heavy wall wart style plugs, and I use a power strip that sits on the floor. If you get one with a built in surge protector you are even better covered. just plug your CPU and monitor into the UPS and every thing else into the power strip.
jlenigk17 07-30-2007 11:34 PM
But can the ups be plugged into the surge protector? It has Auto Volt Reg. on it and surge protection. Can i do UPS to extension cord to outlet?
SecretSquirrel 07-31-2007 06:23 AM
A short extension cord will work just fine, as long as it's 3-wire grounded type. And you are correct, the UPS shouldn't be plugged into a surge protector. Excerpt from an APC instruction manual;
Plug the Back-UPS ES power cord directly into a wall outlet; not a surge
protector or power strip.
jlenigk17 08-02-2007 06:15 PM
For anyone wondering
I did a little research and found that hospital rated outlets, usually the ones with a triangle on them will do the trick. It is required for all those to have a minimum pull force on a cord of 10 pounds. so these outlets can hold heavy duty cord. You can find these at Home Depot or any electrical vendor. Their expensive but if you have vital equip. their the only fool proof solution.
DIYer
cryingeva 08-03-2007 04:09 AM
Thank this advise... saw the light.
