Outlet Postitioning - Electrical - DIY Chatroom Home Improvement Forum
Old 10-22-2012, 10:55 AM   #1
Rewards Points: 20
Outlet Postitioning
Hi, I'm trying to move a bedroom outlet and was wondering if it's against code to have it within 12 inches of the floor. Also, is there a restriction on how close it can be to an adjacent wall (it's in a corner)?
Another problem is that I'd like to avoid splicing in a separate box. The wires will run to the new box, but are unsheathed (they still have their individual insulation, except the ground). Are you allowed to cover the wires with electrical tape or shrink tubing or something until they reach the box? Is this even necessary?
helium44 is offline   Reply With Quote
Old 10-22-2012, 10:59 AM   #2
Licensed electrician
Rewards Points: 1,864
What area s the receptacle in. Some areas like a commercial garage have height requirements.
The splice will need to be made in an accessible junction box. You cannot just tape the splice. You will need to use a listed connector like a wire nut.
Old 10-22-2012, 11:01 AM   #3
joed's Avatar
Rewards Points: 13,682
In the general living area of a home there are no restrictions on putting a receptacle close to the floor or the corner.
You can not make any splices outside of an accessible box. Tape and heat shrink are not acceptable.
Old 10-22-2012, 11:27 AM   #4
Rewards Points: 20
I'm not splicing it outside the box, I'm just running it to the new box, but the 3 wires are no longer covered between the old and new boxes by the sheath. So do I have to cover that?
Old 10-22-2012, 12:20 PM   #5
The sheath needs to extend at least 1/4" into the box. You will need to move the box.
Old 10-22-2012, 05:32 PM   #6
Rewards Points: 20
So there's no way to fix unsheathed wire without replacing it?
Old 10-22-2012, 06:11 PM   #7
joed's Avatar
No matter how you describe or how many times you ask it, ALL SPLICES MUST BE IN ACCESSIBLE BOXES WITH COVERS.
Old 10-24-2012, 04:46 PM   #8
Rewards Points: 20
I'm sorry if I wasn't clear enough, but I'm not trying to splice. I have wires that are fully insulated running into a box, but they have no outer sheath (cloth) that goes around all 3 (hot, neutral, ground) wires. I was wondering if this can be fixed.
Old 10-24-2012, 04:49 PM   #9
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
What I do is just cut a length of sheath from a piece of cable and slide it on the existing wires and apply a few wraps of electrical tape...
The Following User Says Thank You to stickboy1375 For This Useful Post:
helium44 (10-24-2012)
Old 10-24-2012, 07:16 PM   #10
joed's Avatar
NO the cable sheath has to go inside the box.
Old 10-24-2012, 07:18 PM   #11
E2 Electrician
I'm pretty sure it's been established what he can't do, the solution was easy enough.
Switched Outlet Issue mjm Electrical 13 06-14-2015 07:56 PM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
