Outlet By Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 11-18-2009, 08:50 PM   #1
Rewards Points: 31
outlet by panel
I noticed in my basement that there is an outlet attached to the service panel and it has its own 20 amp breaker. Does anybody know what this outlet is for? Is this for future use or something into which a new line/circuit can be tapped?
kupalino is offline   Reply With Quote
Old 11-18-2009, 08:55 PM   #2
An outlet is required for service of any equipment in the basement - HVAC etc
Also at least one outlet is needed in a basement as I understand
I have other outlets in the basement off the outlet by the panel/heating equipment
Old 11-18-2009, 08:56 PM   #3
300zx's Avatar
Post
Alot of times we put a gfci there for sprinkler system to plug into.Could just be there to be thereAre there other outlets in garage?I see scuba posted before i could about the service of equip.
300zx is offline   Reply With Quote
Old 11-18-2009, 09:19 PM   #4
Rewards Points: 31
there is an outlet in the garage and it has its own breaker.
I'm finishing my basement and I think I'll use this to power the outlets I'm adding. There is a separate 15 amp. breaker for the basement lights and I'll use it just for that.
Old 11-18-2009, 09:35 PM   #5
Thumbs up
A dedicated outlet near HVAC units and in boiler rooms is a requirement by the NEC. But this is slightly different. It probably is there for convenience.
Last edited by spark plug; 11-18-2009 at 09:37 PM. Reason: Missing word. ("There").
spark plug is offline   Reply With Quote
Old 11-18-2009, 09:41 PM   #6
210.63 states an outlet must be present, but not a dedicated circuit ??
Old 11-18-2009, 09:43 PM   #7
Most builders place an outlet by the panel for use by the trades during construction.
jerryh3 is offline   Reply With Quote
Old 11-18-2009, 09:50 PM   #8
Thumbs up
Thank you for putting the record straight. I knew that but I (like many other people) am sometimes guilty of Hyperbole. What I really meant to say was that the outlet at the panel (in the case of this OP) was NOT dedicated (and by itself) for any particular mandatory purpose but for convenience. Therefore, it could be tapped into.
p.s: The phrase that I (think I) made up "Eliminate confusion Through Education" applies to me;
Old 11-18-2009, 09:52 PM   #9
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 54
Could be for a washing machine, if the panel is in an area that looks like it could be a laundry room. I could also see it being for equipment such as a DSL modem or something like that, if the phone/cable comes in with the electrical.
Old 11-18-2009, 09:56 PM   #10
Rewards Points: 6,652
I have mine, so that I can connect the networking equipment & server, since the panel is on the same wall, and slightly above it. It also comes in handy when working at the workbench, and needing to charge the battery pack for the DeWalt drill.
Old 11-18-2009, 10:01 PM   #11
OK, I just wanted to make sure there wasn't another part of the code that said one was needed
My circuit does not have much on it....as long as it isn't a hot week in the summer (12k AC), OR the month of December -Christmas display
The last outlet is an outside outlet in the side yard
I actually need to add another outlet for my Network stuff
Old 11-18-2009, 10:32 PM   #12
Lightbulb
Then you'll have 21 outlets...! BTW. I can't wait to see your Christmas display. Hope you'll post.
Old 11-18-2009, 10:59 PM   #13
Actually that one is already counted in the 20
It's one reason I extended the circuit - AC in the summer, outside outlet in the winter
Yup, I'll be posting pics once I'm setup
Old House Rewire finnimus Electrical 15 05-13-2011 11:39 PM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 04:35 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 09:43 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
