Old 04-06-2012, 03:15 PM   #1
Question
Outlet not working
I was doing some work on my rental property and noticed one of the electrical outlets is not working. Tested it and it had no power. I pulled the outlet out and hooked up to it was 2 neutral wires on one side and 1 hot wire on the other although the hot wire had no power. Also going through the box was 2 hot wires pigtailed together. These had power.
When I put the tester to the 2 hot wires pigtailed together and the neutral side of the outlet it lit up. So I connected these 2 hot wires that were pigtailed together to the outlet. When I tested the outlet it read open ground. Any ideas how to fix this? I don't understand why it was wired like this. It is older wiring were the outlets don't have an uninsulated ground.
jmann118 is offline   Reply With Quote
Old 04-06-2012, 03:49 PM   #2
joed's Avatar
Outlet not working
Find the wall switch that controls the third hot wire.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 04-06-2012, 04:39 PM   #3
Outlet not working
thanks. I'm an idiot.
Old 04-06-2012, 07:58 PM   #4
Missouri Bound's Avatar
Outlet not working
Dont take it too hard....I'm sure you aren't the only one.......
Do you want it your way or the right way?
Old 04-06-2012, 07:59 PM   #5
Licensed Electrician
k_buz's Avatar
Outlet not working
At least you didn't pay an electrician to come out because your dishwasher isn't working only to find out that the switch on the counter (you don't know what it does) is turned off.
k_buz is online now   Reply With Quote
Old 04-06-2012, 08:47 PM   #6
Outlet not working
hahahaha I guess we all have our moments
Tags
ground, open ground receptacle, outlet, wiring
Outlet stopped working repeatedly Mebbid Electrical 3 04-25-2011 09:06 AM
Outlet quit working? stevegilmo2004 Electrical 2 03-19-2011 11:22 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 09:38 PM
Outlet not working, reading "open ground" syren Electrical 3 04-19-2010 05:20 PM
