Outlet Not Grounded And There Is Still Voltage Present? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-06-2011, 12:38 AM   #1
Outlet not grounded and there is still voltage present?
I just took a faceplate off of an outlet in preparation for changing the outlet to a newer Decora style outlet...and I'm still seeing some voltage with my little voltage tester, even after shutting off the breaker, but it's not as consistent, my voltage tester light goes on and off randomly. I also notice the bare wire isn't attached to the box. Maybe the box isn't even grounded? Would this have anything to do with the voltage weirdness?
djgrant is offline   Reply With Quote
Old 07-06-2011, 01:14 AM   #2
Learning by Doing
Leah Frances's Avatar
Non-contact testers are famous for picking up phantom voltage. If there is something (like a lamp) plugged into the outlet does it go out when you turn the breaker to the off position?
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 07-06-2011, 01:15 AM   #3
Learning by Doing
Looks like you've got a ground wire there. Other than your tester... Any reason to think it isn't grounded?
Old 07-06-2011, 01:16 AM   #4
Ill try to find my multi meter...maybe that will work better.
Old 07-06-2011, 01:17 AM   #5
Learning by Doing
Work carefully.
Old 07-06-2011, 01:19 AM   #6
I'm just used to seeing a wire connected from the junction box to the bare wire... that's what I meant. But I guess it's still grounded...assuming that bare wire actually connects to something. Right?
So what is the point of connecting ground to the box as I've seen before?
Old 07-06-2011, 03:13 AM   #7
Learning by Doing
Metal boxes need to be grounded. You pigtail the ground from the 'romex' to both the box and outlet.
Is it a plastic box? Hard to tell from the pic. They don't need a separate ground.
Old 07-06-2011, 05:12 AM   #8
Licensed electrician
Rewards Points: 1,030
Leah, I suspect the OP is in Canada. Their boxes, even when plastic, have a spot for the grounding conductor.
This would have nothing to do with the indications the OP is getting. I too suspect a non-contact is being used.
Old 07-06-2011, 11:44 AM   #9
Yeah I was using a non contact tester.
It is a plastic box I think but it has a metal piece with screws in it as shown in pic.
Old 07-06-2011, 01:52 PM   #10
Learning by Doing
GTK, Jim. I had no idea. Thanks for taking the time to point it out. Never seen one of them before
Old 07-06-2011, 01:57 PM   #11
Rewards Points: 590
For what purpose?
operagost is offline   Reply With Quote
Old 07-06-2011, 02:05 PM   #12
Master Electrician
Rewards Points: 3,684
You would connect the grounding conductor to the screw on the metallic strip. The device would then be grounded by the device screw when mounted to the strip.
brric is online now   Reply With Quote
