Old 08-01-2007, 09:52 AM   #1
outlet near tub OK?
Anyone know what NEC says about how close a GFCI outlet can be to a tub? I would like to put an outlet about 6 inches to the side, and 2 feet up from the tub (the wall limits my options). Thanks
matty is offline   Reply With Quote
Old 08-01-2007, 05:14 PM   #2
Master Electrician
JohnJ0906's Avatar
outlet near tub OK?
As long as you are outside the footprint of the tub, you are NEC legal.
You might want a weatherproof cover on that, it's closer than I would prefer to sprayed water. Might not look so good, but safer.
John from Baltimore
One Day at a Time
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
JohnJ0906 is offline   Reply With Quote
Old 08-01-2007, 10:49 PM   #3
remodeling pro
outlet near tub OK?
I would check with local electrical inspector on this one. Proximity of switches and recepticles to tubs and showers is one of those things with wide range of acceptance variations on the local levels. National codes or not, that would not fly in my area.
troubleseeker is offline   Reply With Quote
Electrical outlet hook up. helpless handyman Electrical 4 07-30-2007 09:18 PM
Bathroom outlet - distance from tub?? plbsplbs Electrical 11 07-09-2007 09:22 PM
20a Outlet Vs. 15a Outlet bobo Electrical 3 05-29-2006 11:55 PM
Adding garage outlet Shane Electrical 1 02-23-2006 05:43 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
