Outlet Meltdown... - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-23-2013, 07:09 PM   #16
Rewards Points: 1,512
Wiring from the breaker panel is daisy chained from one receptacle to the next.
There was a loose or corroded connection at the receptacle that had the meltdown.
Loose connections offer resistance to electrical current. When electricity encounters resistance, heat is generated. The more amperes drawn the hotter it gets. You can get the meltdown that is pictured up above before enough amperes are drawn to trip the breaker.
The Following 2 Users Say Thank You to AllanJ For This Useful Post:
Jim Port (01-23-2013), KwaK1980 (01-23-2013)
Old 01-23-2013, 07:10 PM   #17
Rewards Points: 758
I didn't see the pictures earlier as you hadn't posted them.
There is VERY likely damage to the wiring at that receptacle which MAY require the walls to be opened up to repair. This is no insignificant event, the landlord MUST ACT NOW to repair this properly.
AandPDan is offline   Reply With Quote
The Following User Says Thank You to AandPDan For This Useful Post:
Old 01-23-2013, 09:17 PM   #18
joed's Avatar
Rewards Points: 12,852
Looks like the symptoms of a bad back stab gone bad.
The Following User Says Thank You to joed For This Useful Post:
Speedy Petey (01-24-2013)
Old 01-23-2013, 10:03 PM   #19
Rewards Points: 31
If I knew the address i would personally call 311 and get you out of there until it is fixed at your landlords expense...that looks really scary and is a fire waiting to happen...good luck....this coming from an electrician, who lives in calgary and also is a landlord
Olsy is offline   Reply With Quote
The Following User Says Thank You to Olsy For This Useful Post:
KwaK1980 (01-24-2013)
Old 01-23-2013, 10:05 PM   #20
Rewards Points: 31
I thought this too, but it has happened to more than one receptacle
Old 01-23-2013, 10:08 PM   #21
Special User
Rewards Points: 1,230
I see the meltage is on the neutral side. I wonder if you've got two hot legs sharing a neutral somehow?
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 01-23-2013, 10:46 PM   #22
Rewards Points: 27
No telling what may be going on with the electrical system, except it's clearly
inadequate and the place should never have been put out to let. This is
typical slumlord stuff. For all we know, other tenants are plugging in their
electric heaters to this same circuit.
kreemoweet is offline   Reply With Quote
Old 01-23-2013, 11:23 PM   #23
Originally Posted by KwaK1980 View Post
It sucks because I really love this space..it's old, the architecture is funky and as an artist it doubles as my studio space...so it would be sweet if they could rewire all...
That melted receptacle looks like something Salvador Dali would have painted ...
at which Edvard Munch would have Screamed!
sixspeed is offline   Reply With Quote
Old 01-24-2013, 03:19 AM   #24
Outlet Meltdown...
AllenJ has it, nail on the head, if you want to deal with this on your own then get to panel shut down circuit, remove bad outlet if wires are long enough then cut and strip clean section and wire back to new but not cheap 29 cent outlet. then only use space heater that is not like a toaster. Slow heat oil filled first setting only 500watts.
prowner is offline   Reply With Quote
Old 01-24-2013, 06:02 AM   #25
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
Ummm....more than one backstab.
Old 01-24-2013, 06:03 AM   #26
For some reason this almost always does this on the neutral side, even on two-wire circuits.
Old 01-24-2013, 07:22 AM   #27
Rewards Points: 252
I'm not an electrician by any stretch, just an observation. Could this be a branch circuit and the two circuits be on the same phase????
mazzonetv is offline   Reply With Quote
Old 01-24-2013, 07:49 AM   #28
joed's Avatar
Probably because the same guy installed all the receptacles the same way using the back stabs on all of them.
Old 01-24-2013, 08:09 AM   #29
The lengths of wires are probably okay between the outlet boxes. But you would want to inspect the wires inside the box to find out how far towards the back of the box the insulation of each wire got melted.
Old 01-24-2013, 08:20 AM   #30
Rewards Points: 31
He does not own the place and he is not an electrician...the landlord needs to deal with this
Outdoor Outlet seansy59 Electrical 3 03-09-2012 03:50 PM
Swithced Outlet to Ceiling Light/Fan Troubles adamiano86 Electrical 7 01-29-2012 09:36 PM
Switched outlet series Overkll Electrical 4 12-07-2010 07:38 AM
Outlet before light switch; Open Neutral? Fox Electrical 21 09-26-2010 08:38 PM
Help Help richie02 Electrical 7 06-17-2008 08:42 AM
