Outlet Location For Washing Machine - Electrical - DIY Chatroom Home Improvement Forum
Old 11-28-2009, 09:40 AM   #1
Rewards Points: 18
Outlet location for washing machine
Is there an NEC requirement for the location or accessibility of the outlet for a washing machine? I've reviewed the NEC code (section 210 I believe) and it's not quite clear to me. First it seems to say that the outlet for a cord & plug appliance must be accessible, but then it goes on to say that if it isn't accessible, it needs to satisfy a different section of the code.
I'm installing a countertop over a front load washer and (gas) dryer and I'd like to add an outlet below the countertop so that the washer and dryer electrical cords are out-of-view. Currently, the outlet is above the hot and cold water pipes that feed the washing machine. Consequently, the outlet is higher than my planned countertop height. If I must continue to use that outlet, I'll have to cut a hole in the countertop and add a grommet.
This is in a dedicated main floor laundry room in a single family dwelling in Michigan.
Thank you,
Mark (new diy member and first post)
markinmich is offline   Reply With Quote
Old 11-28-2009, 09:46 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
it's an early morning (in my head anyway) and the code sections you refer to elude me. Any chance you can cite the sections you are speaking of?
btw: welcome aboard the board. Where-a-bouts in Michigan are you from? We have several members, including myself, in Michigan.
Old 11-28-2009, 10:36 AM   #3
Licensed electrician
Rewards Points: 1,456
Acessible according to the NEC is different than Websters defines it. NEC accesible means not having to remove building finishes nor permanently closed in by building finishes. The washer is not permanant.
The NEC does have a requirement that the receptacle be located within 6' of the intended location of the machine.
Are the hoses coming up thru the countertop?
Old 11-28-2009, 11:22 AM   #4
Rewards Points: 18
nap and Jim,
Thanks for the quick replies.
nap, the applicable code that is (or was) unclear to me is below. (I live in Rochester.)
Jim, thanks for clarifying the NEC definition of accessible. So by that definition, the washer is not considered permanent and an "out-of-view" receptacle is still considered accessible. Is this correct?
The 6' rqmt is no problem.
I did not plan to bring the water hoses thru the countertop. I was actually thinking of having the countertop on some type of rollers or slide system to access the hot/cold shutoffs. Any idea if this violates a plumbing code?
422.33 Disconnection of Cord-and-Plug-Connected
Appliances.
(A) Separable Connector or an Attachment Plug and
Receptacle. For cord-and-plug-connected appliances, an
accessible separable connector or an accessible plug and
receptacle shall be permitted to serve as the disconnecting
means. Where the separable connector or plug and
receptacle are not accessible, cord-and-plug-connected
appliances shall be provided with disconnecting means in
accordance with 422.31.
422.31 Disconnection of Permanently Connected Appliances.
(A) Rated at Not Over 300 Volt-Amperes or Horsepower. For permanently connected appliances rated at not over 300 volt-amperes or hp, the branch-circuit overcurrent device shall be permitted to serve as the disconnecting means.
(B) Appliances Rated Over 300 Volt-Amperes or Horsepower. For permanently connected appliances rated over 300 volt-amperes or hp, the branch-circuit switch or circuit breaker shall be permitted to serve as the disconnecting means where the switch or circuit breaker is within sight from the appliance or is capable of being locked in the open position. The provision for locking or adding a lock to the disconnecting means shall be installed on or at the switch or circuit breaker used as the disconnecting means and shall remain in place with or without the lock installed.
Also, do you know if a typical non-commercial washing machine over or under 300 Volt-Amperes?
Thanks again! I like this site already!
Old 11-28-2009, 12:30 PM   #5
nap
You talking to me?
nap's Avatar
the permanently connected does not apply because it is cord and plug connected. Permanently refers to hardwired appliances.
the plug serves as the disconnect in your case.
the washer recep in the case of a washer is considered accessible even if below the counter. It appears you have a code book available. If so, look up "accessible" in section 100 definitions. That will belay your concerns.
Old 11-28-2009, 10:38 PM   #6
" Euro " electrician
frenchelectrican's Avatar
Let me add the other thing about the landruy room { Nap check that part to be sure it is legit in your state due I know the OP is the same state as you are }
Per modern code the landury room it have to be on 20 amp circuit that serve the recetaples nothing else out of that room and I am pretty sure you will have to use the GFCI as well
Merci,Marc
Old 11-28-2009, 11:16 PM   #7
Lightbulb
Thank you,
An outlet behind (non-fixed) movable appliances is considered "ACCESSIBLE" in terms of the NEC. Even splice boxes inside a drop ceiling with removable tiles IS considered accessible in the eyes of the NEC (of course not in a physical sense...) (No matter what) Don't Drink and Drive, Ever!!!
spark plug is offline   Reply With Quote
Old 11-29-2009, 11:41 AM   #8
Scared Electrician
Saturday Cowboy's Avatar
The code requires a plug for the washer, it does not care if you mount it at ~48in or if you mount it on the floor just as long as it is there.
volt-amps = fancy term for watts
Most likely -read garentteed you areover 300watts which is about 2.5 amps
so to sum it up just install the plug below countertop, and you will be fine. Same would go for an electric dryer. Can't answer aboout the plumbing tho.
And so it goes, R
Saturday Cowboy is offline   Reply With Quote
Old 11-29-2009, 12:29 PM   #9
Rewards Points: 18
To all, thanks so much for sharing your knowledge and expertise!
Another question: I understand that the NEC is the national code, but does anyone know how the code system segments from there? State code?, County code?, City code?, Subdivision code?.
nap, thanks for referring me to section 100 (Definitions). It is interesting to note that there is a definition for "accessible" and another definition for "readily accessible".
Thanks again,
Mark
Old 11-29-2009, 01:49 PM   #10
nap
You talking to me?
nap's Avatar
Ya, don't ya love it?
In Michigan, they accept the national code with a few alterations. That would be these:
http://www.michigan.gov/documents/dl...n_295688_7.pdf
If you go down to section 801 it explains what was excepted out of the NEC and the rest of the rules implemented in this new code cycle.
I believe there are a few municipalities that do have their own version of the code although not positive of it. I don't deal with any of them being in SW Mi so I cannot say with certainty one way or the other.
BTW: 2008 NEC (with exceptions and other items in Part 8 rules) is in effect starting in December in MI (at least that is what the electrical and building inspectors from my area have told me)
Marc. I did not find anything about a 20 amp circuit being required for the washing machine. That rule does sound familiar somewhere along the line but I cannot find support for it yet.
One thing you need to take note of concerning the recep. I have had different inspectors require different things
1. it does not have to be GFCI because it is dedicated. (if I remember the code section correctly)
2. to qualify for dedicated, (and this is where the different inspectors allow a couple different things) the recep cannot be a duplex but must be a single recep.
That may be where the dedicated circuit Marc and I are thinking of comes in to play. The recep AND circuit must be dedicated for it to not be GFCI.
Now, I have had inspectors allow a duplex as long as it is behind the washer. I have also had inspectors allow you to split the duplex and leave 1 recep NON-FUNCTIONAL and thereby making, effectively, a single recep.
or, of course you can put in a single recep but they usually several times that of a typical recep and many people don't like spending the extra dollars.
Old 11-29-2009, 02:26 PM   #11
The requirement for the 20 amp laundry circuit is located in Article 210.11(C)(2).
Old 11-29-2009, 03:57 PM   #12
nap
You talking to me?
nap's Avatar
yep, right where it's supposed to be. thanks for finding that Jim.
and yes, it states a dedicated circuit and yep, it's a 20 amp circuit.
Old 11-29-2009, 08:32 PM   #13
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,942
Actually it does not require a "plug" for the washer, it requires at least one 120v-20a receptacle for the laundry.
Small details I know, but accuracy of information is important.
Old 11-29-2009, 09:00 PM   #14
Electrician
Originally Posted by Speedy Petey View Post
Actually it does not require a "plug" for the washer, it requires at least one 120v-20a circuit for the laundry.
Fixed that for you. If we're gonna be accurate, we should be accurate.
EBFD6 is offline   Reply With Quote
Old 11-30-2009, 06:14 AM   #15
No, receptacle WAS accurate. I guess "receptacle & circuit" would have been most accurate.
210.52 Dwelling Unit Receptacle Outlets.
(F) Laundry Areas.
In dwelling units, at least one receptacle outlet shall be installed for the laundry.
And yes, the required receptacle must be on a 20A "laundry" circuit, which is 210.11(C)(2).
(2) Laundry Branch Circuits. In addition to the number of branch circuits required by other parts of this section, at least one additional 20-ampere branch circuit shall be provided to supply the laundry receptacle outlet(s) required by 210.52(F). This circuit shall have no other outlets.
Garage outlet location redrumliny Electrical 7 09-05-2009 08:53 AM
Wahing Machine Outlet joedadog Electrical 21 01-17-2009 01:22 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
New coaxial outlet location shimkc Home Theater 1 01-03-2008 09:55 PM
Outlet for pitching machine outdoors NREMTP Electrical 11 06-28-2006 06:18 PM
