Outlet And Lights In A Shed - Electrical - DIY Chatroom Home Improvement Forum
Old 05-05-2009, 10:21 AM   #1
Rewards Points: 346
Outlet and lights in a shed
I have read as man posts as I could related to this subject and I am a bit confused so I will tell you what I want to do and ask a few questions.
I would like to run power to a shed about 140 feet from the panel using 12-2 UF for about 400 watts of lights and two or three outlets from a 20 amp breaker.
Do I need a disconnect at the shed?
Should I be concerned about the 8% voltage drop?
Do I need GFCI in the shed?
Rege
RegeSullivan is offline   Reply With Quote
Old 05-05-2009, 10:33 AM   #2
Voltage drop should not exceed 3% of the rated voltage. 120volts should not have a bigger voltage drop than 3.6 volts.
Paelectrican is offline   Reply With Quote
Old 05-05-2009, 02:04 PM   #3
Motors may not like this much upstream resistance ( Ω) but incand. lighting will last 3x longer. At 20A you'll lose 200w in the wire.
Yes, put in a GFCI.
Old 05-05-2009, 08:01 PM   #4
DIYer
If it's GFCI protected on the house side, you might be able to use the 12 inch shallow bury depth exception for a single buried branch circuit.
Gigs is offline   Reply With Quote
Old 05-05-2009, 08:24 PM   #5
If you just want lights no concern
If you are going to run any motors I'd be concerned about the drop
You would have to go to #8 to get the voltage drop down
At that point I'd buy a spool of #6 & run a small sub
GFCI before the wire & 12" depth OK
Shed should be GFCI protected
All my outlets & lights in my shed are GFCI
--it also borders a pool in my case
If you install a sub install a main breaker panel as a disconnect for sub
Old 05-06-2009, 02:55 PM   #6
Rewards Points: 346
Thanks to everyone that replied.
Light will be the only thing on this circuit. The shed is too small to use as a shop and I can not imagine any situation where I would need power in the shed that would justify the cost of running #6 and putting in a sub panel.
I am wondering if I could run 10-2 into the shed and change to 12-2 to make wiring receptacles a little easier? The cost difference is not that great.
Rege
Old 05-06-2009, 04:34 PM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 240
Rege
You can do this.
Putting in GFI outlet on a timer for xmas lights farmerde Electrical 4 11-20-2008 10:23 PM
Multiple Circuits - Same Outlet box Revnjeff Electrical 2 09-04-2008 09:17 PM
On one outlet my GFCI tester has all three lights lit. What does it mean? Deck Electrical 6 07-09-2008 10:18 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
Outlet in bathroom for lights.... TerryL Electrical 5 10-28-2006 09:46 PM
