Outlet And Light Pigtailed To Power. Ok? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-24-2006, 11:25 AM   #1
Outlet and light pigtailed to power. ok?
I'm trying to power an under cabinet light. It has to be hard wired. I have an outlet right underneath that cabinet.
Can I pigtail the light to the wires already being used by the outlet or is that a bad idea. I want to use the outlet as well. I don't want to get rid of it. So basically the outlet and the light will pull from the same hot wire. I don't want to run new wiring from the basement because it seems like too much work for a cabinet light.
Any info would be appreciated.
skellies is offline   Reply With Quote
Old 06-24-2006, 12:59 PM   #2
Electrician
Rewards Points: 794
Hello
I am not familiar with the NEC, but i know up here in Canada a kitchen rectipical can not be used for anything else.
So in your case that would be a no no up here, not sure what the NEC says but i beleive it is similar.
darren is offline   Reply With Quote
Old 06-24-2006, 01:08 PM   #3
How are you planning on switching the light on and off?
Sparky Joe is offline   Reply With Quote
Breaker for Spot light and outlet receptical hgiljr Electrical 4 08-16-2007 01:10 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 09:44 PM
Tracing a Light Switch to an Outlet spam33 Electrical 17 07-24-2006 03:57 PM
trying to wire a light and light switch off of an outlet imphishy Electrical 3 03-16-2005 09:04 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
