Outlet Issue - Electrical - DIY Chatroom Home Improvement Forum
Old 12-13-2009, 11:19 AM   #1
Outlet Issue
I have 2 outlets that are along the same wall, about 30 feet apart. In one outlet I have plugged in a Carbon Monoxide Detector. In the other is a lamp and the charger for my laptop, which i frequently connect and disconnect. Sometimes when I plug in the charger, there is a small spark and the other outlet seems to turn off and then turn on very quickly (I can tell by the carbon monoxide detector beeping when it resets itself).
I ve looked at both outlets, and everything looks normal. Are they somehow connected to each other? And why would this happen in the first place? I'm getting worried.
thanks
picsaro is offline   Reply With Quote
Old 12-13-2009, 12:02 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Sounds like you may have back stabbed connections on your receptacles causing an intermittent loose connection, If so, pull the wire out and bend a little hook and install the wire on the screws.
wirenut1110 is offline   Reply With Quote
Old 12-13-2009, 12:12 PM   #3
300zx's Avatar
Post
Yes they are prob connected i would change out both oulets sounds like a bad connection and maybe even the other rec on that circuit.
300zx is offline   Reply With Quote
Old 12-13-2009, 12:14 PM   #4
300zx's Avatar
Post
Didn't think about that. That is prob the problem.
Old 12-13-2009, 03:20 PM   #5
thanks for the responses. What does "back stab" mean? The wires are directly into the outlet? If so, neither of them are like that. I replaced both outlets about 2 years ago and the wires are around the screws.
Old 12-13-2009, 03:31 PM   #6
Whichever outlet can't run a hair dryer has a problem, at the outlet or upstream.
Old 12-13-2009, 04:11 PM   #7
300zx's Avatar
Post
Post #7 shows the back stap and one wire around screw Use recept instead of wirenuts okay?
Old 12-13-2009, 05:04 PM   #8
joed's Avatar
Rewards Points: 11,602
It sounds like a loose connection. Pull the receptacle with the carbon monoxide detector and check the connections.
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
outlet issue renshai Electrical 7 11-20-2009 06:35 AM
Outlet issue mb20unofan Electrical 5 07-01-2009 09:35 PM
Unusual electrical issue LosLobo Electrical 7 11-10-2008 02:44 PM
replacing vanity light...issue with outlet box? tarheelblue Electrical 5 01-28-2008 10:20 AM
