Outlet Inside Vanity Cabinet - Does It Need To Be GFCI? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-03-2012, 10:33 PM   #1
Rewards Points: 26
I'm looking to add some lighting underneath my bathroom vanity (ie. LED rope lights). The lights will need to plug into an outlet. To keep things as neat as possible, I will install the outlet inside the vanity cabinet. If I understand correctly, this is allowed by code so long as the outlet is within 12" of the vanity top.
The lights/outlet will be controlled by a wall switch as I don't always want them on. However, I'd also like one of the outlet receptacles to maintain constant power so that I can plug in a rechargeable razor or something. This split cannot be done if the outlet is a GFCI and it seems possible that turning on and off the entire outlet each time may result unnecessary trips of the GFCI breaker.
So, my question is whether this outlet needs to a GFCI? I can't find any direction on the issue one way or another.
LowlyDIYer is offline   Reply With Quote
Old 02-03-2012, 10:44 PM   #2
Electrical Contractor
kbsparky's Avatar
All receptacle outlets in bathrooms must be protected by a listed GFCI device...
-KB
Old 02-03-2012, 10:53 PM   #3
Rewards Points: 26
Thanks. I just found that statement in the code as well. Kind of sucks.
Any suggestions for doing what I'm looking to accomplish - short of adding yet another outlet? Should I be concerned about tripping the breaker by constantly turning off an on the outlet?
I suppose having use of the second receptacle is more of a "nice to have" than anything else...yet, at the same time, if it's there, I'd like to use it.
Any other concerns I should be aware of with the outlet in the cabinet?
Old 02-03-2012, 11:25 PM   #4
Missouri Bound's Avatar
You could use a GFCI breaker for those outlets, and replace all on the circuit with regular receptacles. Then you could split the outlet and still be code compliant.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
LowlyDIYer (02-05-2012)
Old 02-04-2012, 12:11 AM   #5
Rewards Points: 264
Another option you might want to consider would be a direct wire mini-fluorescent under-cabinet fixture. I know home-depot has some that are only 1.5" tall. They also have some plug in ones that might be smaller, which can use a special transformer that allows them to be hardwired.
a_lost_shadow is offline   Reply With Quote
Old 02-04-2012, 06:45 AM   #6
Rewards Points: 26
I'm not sure this is correct based on the wording of the code.
GFCI protection is required for all receptacles in:
Bathrooms
Old 02-04-2012, 06:54 AM   #7
Rewards Points: 77
I'm not sure why that would be true (no expert here). If the breaker is gfci and is feeding the outlets in the bathroom, split one included, the bathroom is gfci protected. There is no criteria for using a gfci outlet vs a breaker that I am aware of.
Not arguing with you just trying to learn if I am misunderstanding something.
Mikenra is offline   Reply With Quote
The Following 4 Users Say Thank You to Mikenra For This Useful Post:
Missouri Bound (02-04-2012), mpoulton (02-04-2012), plummen (02-04-2012), SD515 (02-05-2012)
Old 02-04-2012, 07:23 AM   #8
Rewards Points: 826
You could probably configure a switch on the load side of the existing GFCI then an outlet after the switch. You just need to feed it from the load side neutral and hot and not comingle the load side neutral with other neutrals. The GFCI would always be on, just (part of) the load is switched. This would get you GFCI compliance.
I don't think you can put an outlet in the cabinet though. Isn't there something about not enclosing outlets in cabinets per NEC?
curiousB is offline   Reply With Quote
Old 02-04-2012, 09:32 AM   #9
Master Electrician
Rewards Points: 3,918
I don't think you can put an outlet in the cabinet though. Isn't there something about not enclosing outlets in cabinets per NEC?[/quote]
Totally false.
brric is offline   Reply With Quote
Old 02-04-2012, 09:46 AM   #10
Electrician
SD515's Avatar
Rewards Points: 504
You can put a receptacle in a cabinet. It depends on the situation as to whether it qualifies as one of the required receptacles for that particular room. In the case of a bathroom, a receptacle can be put almost anywhere in any cabinet (within or directly over showers and tubs excluded), as long as it’s done correctly and is accessible, and is GFCI protected. If it’s installed outside the perimeter as specified in 210.52(D), then it wouldn’t qualify as the required receptacle, and another receptacle would have to be installed that does meet the criteria.
Kyle
The Following 2 Users Say Thank You to SD515 For This Useful Post:
brric (02-04-2012), Jim Port (02-04-2012)
Old 02-04-2012, 01:58 PM   #11
Rewards Points: 26
No worries. I don't know either, which is why I'm asking the question. You may very well be right.
My immediate thought went to a garbage disposal/dishwasher set up in the kitchen. That is NOT a GFCI receptacle. However, in looking at NEC, it doesn't need to be; only outlets above the counter need to be GFCI. They make no such provision for bathrooms; they simply say all must be GFCI protected.
Old 02-04-2012, 02:22 PM   #12
Master Electrician
Which part of ALL is so hard to understand?
Old 02-04-2012, 03:01 PM   #13
Micro switch installed on the cabinet door so the lights go on when the door is opened. Wired after the GFCI and before the light. Something like this: http://www.rockler.com/product.cfm?page=5239 though I am sure there are several switches that would work. I am planning on doing that in my closet.
justin_bliar is offline   Reply With Quote
Old 02-04-2012, 05:22 PM   #14
Semi-Pro Electro-Geek
Rewards Points: 2,970
[/size][/font][/size][/font]
"GFCI protected" means just that. It doesn't say (or mean) that the receptacle itself has to be a GFCI receptacle. That is never required anywhere. The NEC only ever requires GFCI protection, which can be provided by any means you want: breaker, receptacle, dead-front device, whatever.
mpoulton is offline   Reply With Quote
The Following 2 Users Say Thank You to mpoulton For This Useful Post:
LowlyDIYer (02-05-2012), SD515 (02-05-2012)
Old 02-04-2012, 06:19 PM   #15
Rewards Points: 826
Which part of rude and condescending is hard to understand?
10 amp Vacuum popping GFCI Outlet brgmgb Electrical 19 12-29-2011 10:45 PM
GFCI outlet in bathroom - HELP PLEASE! oldhouseguy Electrical 10 12-06-2011 11:47 AM
How to include a GFCI outlet with multiple loads Gwennr Electrical 5 10-13-2010 10:31 AM
GFCI outlet feeding sub panel tdola Electrical 1 07-13-2010 02:15 PM
two GFCI outlets at bath vanity Hickory Electrical 6 12-18-2005 09:31 AM
