Outlet Help - Electrical - DIY Chatroom Home Improvement Forum
Old 05-30-2012, 01:28 PM   #1
outlet help
i bought an air conditoner so i bought a 20amp 250 volt outlet well its a single outlet well my old outlet was a 15amp outlet and had 2black 2white and a ground wire........but this new outlet only needs 3 wires so what ones do i hook up?
dasyckwun is offline   Reply With Quote
Old 05-30-2012, 01:44 PM   #2
none of the above.
You must run new wire. A 15 amp outlet most likely had 14 wire you need 12. You also need a dual pole 20 amp breaker to hook it to.
The wires on that outlet sound like you have power coming in from another outlet or the power panel and a feed going out to the next outlet in the chain. Even if this was 12guage wire you will mess up the whole string of outlets if you were to hook this up to a 20 amp 220 breaker.
bill01 is offline   Reply With Quote
Old 05-30-2012, 04:28 PM   #3
Sparky
Rewards Points: 510
You're going to have to run a new dedicated circuit, or get a 120V AC.
Techy is offline   Reply With Quote
Old 05-30-2012, 04:32 PM   #4
Licensed electrician
Rewards Points: 1,028
It might even be a good idea to run a new circuit even if the unit is 120 to avoid tripping due to overloads.
A new circuit is definitely needed for the 240 volt unit.
Old 05-31-2012, 12:16 AM   #5
" Euro " electrician
frenchelectrican's Avatar
As other poster reply the answer to you but let me ask you this one is this window shaker ( window A/C unit ) is really a 240 volt unit ? you may want to double check the nameplate to verify it.
The only time I have see the window shaker that run on 240 volts is pretty big arse unit ( more than 18,000 BTU sizewise ) in stateside.
Merci,
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
k_buz (05-31-2012)
Switched Outlet Issue mjm Electrical 13 06-14-2015 08:56 PM
Help rewiring 220V 3-prong outlet to 4-prong grounded outlet madmaxwell Electrical 7 03-23-2012 07:37 AM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 05:14 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 10:13 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
