Outlet Help - Electrical - DIY Chatroom Home Improvement Forum
Old 04-18-2011, 03:25 PM   #1
outlet help
Today i was attempting to getting an outlet out of wall because it was too far in and i wasn't able to plug things into it. and i took off the cover plate and unscrewed the outlet thinking it would pull itself out. but instead it sparked and tripped the circuit. it fried the outlet and i had to disconnect it. I know i should have shut off the power first but i have 2 questions.
what can I use to take the outlet farther out of the wall so i can plug things into it? Is there anyway?
What would happen if i used the fried outlet again?
I'm sorry if i sound like an idiot asking dumb questions but i am not a professional
jmans8666 is offline   Reply With Quote
Old 04-18-2011, 03:35 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,276
Why is the receptacle box set so deep? Post a picture./ You can get box extenders to bring the box out flush with the wall surface.
If you try to reuse a "fried" receptacle, it gets "refried". Toss it and get new.
Coastal South Carolina
rjniles is offline   Reply With Quote
Old 04-18-2011, 03:42 PM   #3
The Box is set so deep because its just an old metal box original to the house and its very loose and thats why it eventually got pushed back so far in the wall. should i just buy a remodel box?
Old 04-18-2011, 04:20 PM   #4
A "Handy Husband"
rjniles's Avatar
If you can get the box out to the wall surface level, drill 2 holes thru the side of the box and secure with sheet metal screws. If after securing it is still too deep, get a plastic box extender to get it to flush. Install a new receptacle.
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
The Following User Says Thank You to rjniles For This Useful Post:
jmans8666 (04-18-2011)
Old 04-18-2011, 04:50 PM   #5
Scared Electrician
Saturday Cowboy's Avatar
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Switched Outlet Issue mjm Electrical 13 06-14-2015 07:56 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 05:13 PM
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
