Outlet Height In Toilet Stall - Electrical - DIY Chatroom Home Improvement Forum
Old 12-12-2012, 12:21 PM   #1
Rewards Points: 278
outlet height in toilet stall
Have a toilet only room with door, I want to add a electrical outlet.
By code how high should it be off the floor? I know the outlets I have seen are all above counter.
DIYGST is offline   Reply With Quote
Old 12-12-2012, 01:55 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
No height requirement. Just high enough that you don't piss on it.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
The Following User Says Thank You to electures For This Useful Post:
Speedy Petey (12-12-2012)
Old 12-12-2012, 01:56 PM   #3
To my knowledge, code does not specify how high an outlet should be. For example in apartments designed for elderly people, outlets are sometimes mounted higher up so they don't need to bend down to plug something in.
So far as a bathroom, you could have an outlet for vacuuming or whatever and that could be on a wall at the same height as other outlets in the house. Or if in an area with a mirror, then high up so easy to plug in shavers, hair dryers, etc. Or if for an electric toilet or electric bidet seat and mounted behind the toilet, then mounted exceptionally low so the toilet tank will not be blocking it (get toilet first and see what will work).
In general bathrooms are required to have GFCI outlets and be on their own 20 amp circuit. This is for those power hog hair dryers. Sounds like you may not have that though? Anyway check with your local electrical inspector as to what is required. They are the final word on everything!
Billy_Bob is offline   Reply With Quote
Old 12-12-2012, 03:30 PM   #4
Rewards Points: 278
It will be used for a bidet seat so ideally low, but it would be to the side of the bowl instead of back below the bowl, because the wall outside the stall already has a counter height outlet for the sink, so it is easy to go straight down in the same cavity between the studs and install new outlet in the bathroom side. the stall desperately need a night light too.
by the way, what tools would I need to drill and fish to the next stud over, given 2 openings?
| x | |
| | x |
x = outlet holes
Please advise on slow flushing toilet? WillK Plumbing 5 03-12-2012 09:58 AM
Adjusting Toilet Flange height burbanol Plumbing 15 12-17-2011 06:45 PM
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Toilet flange height Joe F Plumbing 2 10-22-2010 07:49 PM
stove gas outlet height amakarevic Plumbing 1 10-05-2008 05:22 PM
