Outlet Height In Garages - Electrical - DIY Chatroom Home Improvement Forum
Old 02-13-2009, 06:56 PM   #1
Outlet height in garages
Is there a specific height that electrical outlets have to be from the floor of garages/carports? I know they have to be GFCI but not sure about the height. Seems to me that I read somewhere 36" but that seems like a bit much.
steve37887 is offline   Reply With Quote
Old 02-13-2009, 08:36 PM   #2
Electrician
You can install them wherever you like.
chris75 is offline   Reply With Quote
Old 02-13-2009, 08:40 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,876
There is no code regarding this, but 48" seems to be a common height.
Old 02-13-2009, 08:43 PM   #4
Electrician
I put them at switch height myself...
Old 02-13-2009, 08:46 PM   #5
It's easier to plug & unplug stuff when they are higher up
For me 36" is about a min
Old 02-13-2009, 09:00 PM   #6
Licensed Pro
I set them at 54" in garages so that ubiquitous piece of plywood leaning against the wall doesn't hide them.
Old 02-13-2009, 10:50 PM   #7
Idiot Emeritus
Rewards Points: 1,492
I'm not absolutely certain, but I believe that a garage that has the ability to store motor vehicles is a classified (hazardous) area.
If true, this means that there cannot be any source of ignition within 18" of the floor. Electrical receptacles and switches are considered a source of ignition unless they're listed for use in classified atmospheres.
This is why water heaters and furnaces are installed on platforms, and not directly on the floor.
Rob
P.S. Hopefully, KCtermite will chime in on this one, he's got a pretty good handle on code issues.
micromind is offline   Reply With Quote
Old 02-13-2009, 11:09 PM   #8
Rewards Points: 1,016
varies
24x30 garage / workshop
I put most at 48" - except for one wall that has a long work bench, there I put several about a few inches above the workbench height.
Old 02-13-2009, 11:22 PM   #9
Rob
If this is true you would have to have EVERYTHING in your garage piped in IMC or Rigid..... You know you can still create an arc just plugging something in or flipping a switch? I don't think you can have any switches or receptacles in a hazardous location.... To the OP I don't think there is a requirement for height( I'm too lazy to go out in the 20 degree weather, and get my code book). Best of Luck! Don't do anything hot! Ben
swaterbenny is offline   Reply With Quote
Old 02-14-2009, 12:31 AM   #10
Registered User
Termite's Avatar
Rob
There is no height requirement for garage receptacles. Most around here set them at about 48".
Ignition sources have to be elevated above 18" in garages. That's basically because of the potential for combustible heavy vapor buildup. The challenging gray area is the mysterious definition of sources of ignition. In my opinion, this code was put in place to prevent water heater installation (or furnaces) on the garage floor back before they mandated the change to sealed combustion water heaters (which an ICC memorandum now allows on garage floors).
Honestly, I've never in all my years had anyone install a receptacle, switch or panel within 18" of a garage floor, so I've never had to make this call. If I had to take a stance I would not permit anything that could throw a spark/arc within that 18" space, and that includes receptacles and switches. Better to err on the safe side.
Old 02-14-2009, 12:36 AM   #11
Registered User
Termite's Avatar
I think Micromind was referring to the hazardous nature of garages due to combustible products (gas, cars, lawnmowers, paint thinner, etc), not the physical protection requirements of wiring.
Old 02-14-2009, 12:38 AM   #12
Idiot Emeritus
The hazardous area is only from the floor up 18". The area more than 18" off the floor is non-hazardous.
Rob
Old 02-14-2009, 01:03 AM   #13
Registered User
Termite's Avatar
Correct!
Old 02-14-2009, 09:06 AM   #14
I'm actually insulating & finishing my garage - living space above
So my wire will be in the walls/joists
If I had to add anything after I'd probably run conduit
But its going to have plenty of power with a 100a sub
Old 02-14-2009, 09:54 AM   #15
Thanks guys. I appreciate all the info.
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
stove gas outlet height amakarevic Plumbing 1 10-05-2008 06:22 PM
outlet height beneath large casement windows DangerMouse Electrical 3 07-29-2008 03:09 PM
Minimum outlet height? Taipans Electrical 32 03-04-2008 04:31 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
