Outlet For Furnace Is Dead - Electrical - DIY Chatroom Home Improvement Forum
Old 12-05-2011, 12:46 PM   #1
outlet for furnace is dead
yesterday my furnace shut off and the thermostat control panel went dead. I discovered that the bussman fuse located at the outlet was blown. A small space heater had been plugged into an adjacent outlet that must be ran on the same circuit. Today i replaced the fuse but still get no power from the outlet. The circuit breaker doesnt appear to be getting tripped. The temps here have dropped below freezing at night so i really need to get this problem solved.
eric784 is offline   Reply With Quote
Old 12-05-2011, 01:13 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 340
Ayuh,... Turn it all the way Off, then all the way back On, 'n check yer outlet...
Bondo is online now   Reply With Quote
Old 12-05-2011, 01:28 PM   #3
sorry i guess i should have stated that i have done that already. all the breakers have been reset after replacing the fuse.
Old 12-05-2011, 01:43 PM   #4
Mad Scientist
With the breaker off, start opening up and inspecting the outlet boxes on that circuit. I'll bet the load from the space heater burned a loose connection open.
McSteve is offline   Reply With Quote
Old 12-05-2011, 09:05 PM   #5
this is why furnaces are supposed to have their own dedicated circuit.
swschrad is offline   Reply With Quote
The Following User Says Thank You to swschrad For This Useful Post:
ben's plumbing (12-05-2011)
Old 12-05-2011, 09:09 PM   #6
Rewards Points: 582
did you make sure the fuse was good.....alot of these fuses been around long time.....just saying....check with meter....
Tags
bussman , furnace , fuse , heater
Odd voltages at outlet TJF Electrical 12 11-01-2011 10:13 PM
Dead outlet, what is easiest way to trace?? walt1122 Electrical 6 08-29-2011 06:06 PM
Changing Two Gang Outlet to Three Gang Outlet vbullinger Electrical 9 01-10-2011 06:13 PM
Expanding dead outlet problem gohanman Electrical 4 08-16-2010 12:15 PM
Outlet is dead but ears are hot!? Whassup? Hubandwif Electrical 33 03-23-2009 09:01 PM
