I've been in my home for a year and knew that the dryer outlet was a 3 prong receptable and assumed it was fine as the house was built prior to the requirement for 4 prongs.
Today I took delivery of a new dryer and when I was assisting in removing the old dryer I noticed that the receptacle is actually a 50A range receptacle and not a 3 prong dryer.
I went over to the fuse box and the installed fuse is 40A.
Did my home inspector mess up or am I missing something?
What is the proper way to correct this? My electrical experience is limited to installing GFCI's and light fixtures.
For some strange reason, I have been going on a lot of service calls caused via Home inspection sheets, the best part is the stuff they miss, vs the items they find non code compliment... it really makes me wonder.
You should install the proper 30 amp dryer receptacle. If there is a ground wire present then install a four prong receptacle.
Change the fuses to 30 amps.
By 'fuse', do you mean an actual fuse that's about 3/4" in diameter and about 3" long and has brass ends, or is it a circuit breaker; a sort of switch that, in this case, is 2 switches tied together, and has 40 marked on it?
Yeah half the things they find are non-issues. The stuff they miss is the real laugh. You can make some good customers by telling them the flagged problems aren't problems at all and there's no need to fix them. Save a few bucks for them and they'll love you for life.
Double tapped breakers and two or three grounds under one screw are the most common laughs I see.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
