Outlet Don't Work - Electrical - DIY Chatroom Home Improvement Forum
Old 10-04-2008, 07:39 PM   #1
Question
Outlet Don't Work
This morning when I woke up 5 of my outlets were not working. I replaced the circut breaker and that did not fix the problem. I pulled out all 5 of my plugs and inspected the wiring and everything looks fine. I do not know what else it could be!!! Any suggestions????
Aha3876964 is offline   Reply With Quote
Old 10-04-2008, 07:45 PM   #2
Electrician
You need to start with the panel, actually make sure power is being supplied to the circuit not working, then I would start looking for a bad connection, backstabbed device. Also, is this in an area where a GFCI may be installed?
chris75 is offline   Reply With Quote
Old 10-04-2008, 07:55 PM   #3
<P>They are not GFCI outlets.&nbsp; How would you know or test if you are getting power to the circut?</P>
Old 10-04-2008, 08:11 PM   #4
Rewards Points: 2,350
You need a multimeter or even a test light. Check for voltage to ground from the black to ground and from the black to neutral. Are the receptacles wired by stabbing the wires into the back? Or are the wires wrapped around screws? You either have an open hot, an open neutral, or both. If it is an open hot, your tester will not read anything. If it is an open neutral, you will have voltage between the black and ground, but none (or very little) between black and white.
AC Outlet voltage diagnosis dwi Electrical 8 06-18-2008 02:26 PM
Help Help richie02 Electrical 7 06-17-2008 09:42 AM
replacing vanity light...issue with outlet box? tarheelblue Electrical 5 01-28-2008 10:20 AM
Microwave Outlet Move Rsinc25 Electrical 3 11-22-2007 04:46 PM
Adding garage outlet Shane Electrical 1 02-23-2006 05:43 PM
