Outlet Doesnt Work - Electrical - DIY Chatroom Home Improvement Forum
Old 01-15-2012, 11:44 PM   #1
outlet doesnt work
7 outlets dont work breaker did not trip
piedmont2 is offline   Reply With Quote
Old 01-16-2012, 12:04 AM   #2
Rewards Points: 83
We really need more... Did this just start? Was it working in the past? How long ago? Did you or anyone else unscrew any plates on light switches or outlet receptacles? Are these 7 outlets supposed to be all on the same circuit? If so, are there other outlets on this circuit that are still working, or does the entire circuit seem dead? Any storms lately?
darlingm is offline   Reply With Quote
Old 01-16-2012, 12:22 AM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
Originally Posted by piedmont2 View Post
7 outlets don't work breaker did not trip
Congratulations ...
Do you have a voltage tester or a non contact voltage tester ?
First thing is to determine if you have power at the receptacles, if you have power then you have lost a neutral connection. If your receptacles are backstabbed and the wires are not wrapped around the side plate screw that would be a good place to start.
As a homeowner you might try plugging a lamp or radio into these non working receptacles and kinda wiggle the plug and see if the circuit comes back on which would be indicated by the light working or radio coming on. If that happens then you have found the outlet where the problem exists.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Outlet neutral bonded to ground? rjniles Electrical 1 07-19-2008 11:12 AM
Help Help richie02 Electrical 7 06-17-2008 08:42 AM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
