Outlet Doesn't Work - Electrical - DIY Chatroom Home Improvement Forum
Old 10-10-2011, 08:22 PM   #1
Outlet doesn't work
The other day one of the circuit popped and when I flipped it back over two outlets and one light socket don't get power (tested with volt meter). Everything else on the same circuit works just fine. Both the outlets and the light socket are in the same place.
msparlin is offline   Reply With Quote
Old 10-11-2011, 01:12 AM   #2
Thadius856's Avatar
Rewards Points: 504
They're probably on the end of the line.
You'll need to check connections at each of those devices, and then locate which device they're fed from and check the connections there.
Is you have use of a volt meter, I'll assume you've checked all GFCIs on that circuit for tripping.
Thadius856 is offline   Reply With Quote
Changing 2 way switch to control light, not outlet? andysam Electrical 0 05-30-2011 10:20 PM
Add An Outdoor Outlet pokey302 Electrical 3 02-21-2011 09:46 AM
What did i do wrong? - Outlet install trips breaker nymex Electrical 22 05-07-2009 03:44 PM
Help Help richie02 Electrical 7 06-17-2008 09:42 AM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
