Outlet With Decreased Power - Electrical - DIY Chatroom Home Improvement Forum
Old 10-08-2007, 07:19 PM   #1
Outlet with decreased power
What causes an outlet to have less power then the other outlets on the same circuit? I have already change the outlet but the problem continues. Is it a bad breaker?
wolverine0222 is offline   Reply With Quote
Old 10-08-2007, 07:54 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 478
What do you mean decreased power?
Les voltage, or no voltage?
More than likely a loose connection between the oulet feeding this one and the one you replaced.
jbfan is online now   Reply With Quote
Old 10-08-2007, 09:32 PM   #3
Electrician
Maybe a dimmer installed... was that receptacle once switched?
chris75 is offline   Reply With Quote
Old 10-08-2007, 10:05 PM   #4
Contractor in PA
I agree with Jbfan, it is most likely caused by a loose or poor connection in the outlet ahead of the one with the problem or a damaged wire.
michaelpwalton1 is offline   Reply With Quote
Old 10-12-2007, 11:15 AM   #5
Rewards Points: 160
Did you measure the voltage? 110 - 130 is okay. Voltage levels can fluctuate to a small degree.
Old 10-13-2007, 09:21 AM   #6
Most modern digital testers would not pick up a loose connection while testing for voltage. They simply do not put enough of a load on the circuit to detect the voltage drop.
Sometimes what can happen is that you will see good voltage with the tester, but when you try to run a load (vacume for example) you notice the decreased power.
Look for a loose connection at any of the recepticles on that circuit.
Master Electrician
jwhite is offline   Reply With Quote
Old 10-13-2007, 02:23 PM   #7
I live in southern California, and I've notice that the AC voltage varies during the time of day especially in the summer when it is hot. At first I thought there was something wrong with my electrical system, and then I realized that it had to do with the overall power demand in the area. Since the power is only low at one receptacle, power usage is obviously not the problem. I would check your connections and outlet.
sluggermike is offline   Reply With Quote
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
kitchen outlet no power apt238 Electrical 27 08-25-2006 07:37 AM
Outlet and light pigtailed to power. ok? skellies Electrical 2 06-24-2006 01:08 PM
Adding garage outlet Shane Electrical 1 02-23-2006 04:43 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
