Outlet Is Dead But Ears Are Hot!? Whassup? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-21-2009, 02:20 PM   #16
Originally Posted by PaliBob View Post
at 123 vac Line the Wiggy drew 27.5 mA Line to N
When I checked from Line to grd the GFCI tripped
Bob L. 3/20/09
So the solenoid impedance, Z, = 123v/.0275A = 4.5 kohm.
If you measure the DC resistance then the coil reactance due to its inductance can also be figured out.
The test resistor in a GFCI is about 16k, so this will definitely trip GFCIs.
Old 03-21-2009, 03:13 PM   #17
For troubleshooting a Wiggy, which has a very low impedance because it pulls current through a solenoid, is a valuable test tool.
Here is a lower cost Wiiggy type tester since the name Wiigy is trademarked.http://www.lowes.com/lowes/lkn?actio...Voltage+Tester
I'm with you Bob. Wiggys thake the guesswork out of the process. Iam an hvac guy and my wiggy does not leave my belt during summer cooling season.
hvaclover is offline   Reply With Quote
Old 03-21-2009, 03:52 PM   #18
The main plus is that it doesn't respond to phantom voltages, and since you have some idea of what voltage is "normal" [120, 240, 460] it doesn't need to be very accurate. And it's rugged.
Old 03-21-2009, 05:57 PM   #19
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Many of the Electrical Plug-Iin three light testers also have a GFCI test button that connects a resistor between the Hot and ground to verify that the GFCI will trip. HF has the Tester without the GFCI Test button for $2.99 and with the Test button for $4.99.
http://www.harborfreight.com/cpi/cta...emnumber=32906
For the small increase in price the GFCI Test is worth it. For example sometimes downstream receptacles are wired off the 'Load' terminals of a GFCI and are not marked "GFCI PROTECTED" By using the GFCI Test button a user can tell whether or not a GFCI or GFCI breaker is upstream.
The best GFCI tester is still the GFCI TEST button. These work the same way in that they connect a bleed resistor to the HOT, but instead of connecting the other end through a pushbutton switch to ground the other end in connected to the Neutral before the CT. What this does is make the GFCI test button work even if there is no EGC (Equipment Grounding Conductor).
The GFCI will still trip on the current differential. The GFCI does not depend on the EGC for its on board test circuit.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-21-2009, 06:31 PM   #20
Tool Geek
PaliBob's Avatar
Originally Posted by Yoyizit View Post
The main plus is that it doesn't respond to phantom voltages.....
For Dimmer ckts especially 3-Way dimmers the Wiggy saves the day.
MY two other most used tools are the three light receptacle GFCI Tester and this Voltage Sniffer:
http://www.all-spec.com/1/viewitem/G...=yahooshopping
This GT-16 model has an adjustable threshold that also works as an almost fool-proof on/off switch. Tracing Low voltage ckts and finding opens in outdoor lights is a real plus.
Outlet is dead but ears are hot!? Whassup?-greenlee-gt-16-1st.jpg   Outlet is dead but ears are hot!? Whassup?-greenlee-gt-16-detector.jpg
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-22-2009, 02:41 PM   #21
Got my first Wiggy back in 60 when I was an electrician in the Navy.
hayewe farm is offline   Reply With Quote
Old 03-22-2009, 03:38 PM   #22
They call it a BJ nowdays.
220/221 is offline   Reply With Quote
Old 03-22-2009, 03:41 PM   #23
It's not polite to mess with and old man.
Old 03-22-2009, 03:55 PM   #24
YEAH!
Where's my friggin' Viagra....
Old 03-22-2009, 06:06 PM   #25
Hey, it's not often that I find the opportunity to find someone older than me.
I got my first wiggy when I was 18.
I got my fisrt voltage tester a few years after that.
Old 03-22-2009, 08:07 PM   #26
Tool Geek
PaliBob's Avatar
Here I thought that BJ was the friend of Barney the purple dinosaur.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 03-22-2009, 08:44 PM   #27
I just now got the joke..duho
Old 03-22-2009, 08:54 PM   #28
That's what Monica thought!
Old 03-22-2009, 09:25 PM   #29
Oops, I think I got this thread a little of topic.
Old 03-22-2009, 09:33 PM   #30
Advice worth 2 cents!
Rewards Points: 150
Sorry I don't have the time nor the talent to explain just how far off this remark is. Z does not equal E/I !!!! and no, you cannot measure the DC resistance to find reactance...NOT! (hint: iron has something to do with the answer)
_pete
---pete
HandyPete is offline   Reply With Quote
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Help Help richie02 Electrical 7 06-17-2008 08:42 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
Dead outlet and switches on otherwise live circuit viking1974 Electrical 4 08-23-2007 05:30 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
