Outlet Converter-Adapter Question - Electrical - DIY Chatroom Home Improvement Forum
Old 07-14-2011, 06:30 AM   #1
delete this message, answered.
doctormonster is offline   Reply With Quote
Old 07-14-2011, 06:36 AM   #2
AfterDinnerDIY.com
Looks British?
If so, you need something to convert 240 to 120v and then an adapter to convert the plug. If you look on the side of the device, it will give a voltage range or just a voltage. Many computer adapters work 120 to 240v and do not require an inverter if so, it would only need a plug to make it fit.
Try Amazon's website but change the country to England and then search for a travel adapter.
AfterDinner is offline   Reply With Quote
The Following User Says Thank You to AfterDinner For This Useful Post:
doctormonster (07-14-2011)
Old 07-14-2011, 06:48 AM   #3
Semi-Pro Electro-Geek
Rewards Points: 2,942
Looks like a 240V 20A plug there. Window air conditioner, right? Unfortunately, you can't plug it into the outlet in the second picture under any circumstances. It may require more than twice as much power as that outlet can provide. There is no adapter capable of fixing that problem. You'll need a dedicated 240V 20A circuit to run that thing.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
Old 07-14-2011, 06:50 AM   #4
I=E/R
a7ecorsair's Avatar
What is the top device? What is written on it for power? It almost looks like the top device would fit into a NEMA 6-20 which is 240 volts.
a7ecorsair is offline   Reply With Quote
The Following User Says Thank You to a7ecorsair For This Useful Post:
Old 07-14-2011, 08:49 PM   #5
First, let me thank everyone for their comments.
@mpoulton: yes, that's exactly it. it's an air conditioner I'm trying to connect to a timed outlet. I have an old model air conditioner and it runs constantly.
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Outlet and Switch question ich00 Electrical 3 05-04-2010 04:02 PM
Outlet not working, reading "open ground" syren Electrical 3 04-19-2010 04:20 PM
Question - outlet with 90 V output? dantm Electrical 3 03-27-2010 02:32 PM
Replacing a section of copper pipe to a Gas Water Heater outlet Question F150dad77 Plumbing 4 10-07-2009 08:32 AM
