Outlet Controlled By A Wall Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 04-30-2009, 03:48 PM   #1
Outlet controlled by a wall switch
hi all
i have a outlet that is controlled by a wall switch, the only thing plugged into it is a lamp.
some days the outlet will work and other times it will not work
if i leave it alone for a few days then retry it again it works.
does this sound like a bad switch or a wiring problem in the wall?
rwright46 is offline   Reply With Quote
Old 04-30-2009, 03:58 PM   #2
Bigplanz's Avatar
Rewards Points: 990
Originally Posted by rwright46 View Post
hi all
Could be either, but I'd check the switch first. That's the component that is getting stressed all the time with off/on, off/on, etc. so it is the first suspect. Easy to test though.
Bigplanz is offline   Reply With Quote
Old 04-30-2009, 04:02 PM   #3
Device are prone to fail much more than wiring....unless it's not stock wiring.
Replace the sw and recep.
Don't forget to break the tab if it's a half switched recep. (look closely at the hot side terminals)
220/221 is offline   Reply With Quote
Old 04-30-2009, 04:02 PM   #4
BIGRED
Rewards Points: 252
It sounds like loose screws. Mebbe on the switch, mebbe on the outlet, mebbe in the plug for the lamp, mebbe in the socket for the lamp. Maybe all of them. If you do not work with this a lot I would suggest turning off the breaker for this area first; then take stuff apart and snug up all the screws.
Grampa Bud is offline   Reply With Quote
Old 04-30-2009, 04:05 PM   #5
thank to all that replied
Old 04-30-2009, 05:00 PM   #6
You have a voltmeter?
3 way switch with 2 fixtures controlled independently? Terry B Electrical 6 05-05-2009 06:34 PM
Motion switch wired to two circuits Sibkuz Electrical 2 04-22-2009 07:31 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 01:19 AM
Wall Switch sue Electrical 4 02-06-2005 07:05 PM
installing a light fixture on a switch controlled outlet Unregistered Electrical 1 02-24-2004 10:51 PM
