-   -   Outlet controlled by switch (http://www.diychatroom.com/f18/outlet-controlled-switch-1116/)
Shardi 10-08-2005 02:21 PM
I have an outlet that is controlled by a wall switch and I replaced the switch and outlet so that the color matched the room since I painted. I put all the wires in the same place on the new switch and outlet but now the switch does not work - the outlet has power no matter if the switch is on or off.
Any help would be appreciated:)
K2eoj 10-08-2005 07:19 PM
Sounds like you got a couple of black wires mixed up. Hard to troubleshoot from here but if it was working before it should not be to hard to get it back. HS.
Teetorbilt 10-08-2005 07:20 PM
Shardi, If you remove the receptacle and look on the side where the black and (possibly) red wire is, you will see a bridge between the two terminals. It is usually brass and has a raised part. Take some needlenose pliers to the raised part and break the connection between the two terminals. Your switch should work again.
K2eoj 10-08-2005 08:18 PM
Yes Teetor is correct. I just ran back to change my post and he was here first. That would make it a half switched receptacle. There is probably a tab on the white side that does not need to be broken. I hope there was no harm done by my first post. HS
Shardi 10-09-2005 06:24 PM
That worked like a charm, thanks to you both
