Outlet Controlled By Light Switch Questions. - Electrical - DIY Chatroom Home Improvement Forum
Old 01-25-2012, 03:16 PM   #1
Rewards Points: 200
Outlet controlled by light switch questions.
Hi there. I recently put in new outlets in my house. There was 3 wire cabling but they were all 2 prong outlets, so I swapped them out accordingly. Some outlets are controlled by light switches, which I love since I have no ceiling mounted lighting in almost all of the rooms. Once I swapped them out, I realized the outlets in question were always on.
Of course, I did my homework searching and came across an answer:
Which got me curious... Let's say outlet 1 is controlled by the light switch, but I would rather outlet 3 be controlled by it on the other side of the room. In order to do that, would we be talking pretty crazy re-wiring? I suppose it wouldn't be as simple as breaking the tab on outlet 3, correct?
As always, thanks guys!
roasted is offline   Reply With Quote
Old 01-25-2012, 03:33 PM   #2
You would need to wire receptacle 3 to the switch. If you just break the tab on receptacle 3 you will just have half a plug that doesn't work. It's definitely a wall full of holes job.
fdiddy is offline   Reply With Quote
Old 01-25-2012, 04:08 PM   #3
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
You could add a switch for each individual outlet but it would have to be around the same area above the outlet to do this. It's possible to make a hold the size of a switch box above the outlet fish wire to the outlet wire them up and you have a switched outlet but make sure all this is allowed and you do it to code.
You could also run wire from the wall outlet down to the basement and back up somewhere else to a switch but that takes a lot more work to get it right.
rrolleston is offline   Reply With Quote
Old 01-25-2012, 05:30 PM   #4
joed's Avatar
Rewards Points: 12,850
It depends on the cabling. Likely if receptacle #3 was never switched you will need some new cabling. If you tell us the cabling in the receptacles we can tell you what is possible.
Old 01-25-2012, 07:02 PM   #5
" Euro " electrician
frenchelectrican's Avatar
The key issue is the numbers of conductors in the receptale box if you have a extra one which it will be coloured diffrent useally red in most case that is switched control circuit but for the rest of the receptales in that room you may want to check the rest of it to see you have them in there.
If you do that will be good you can change the switched half duplex to diffrent location.
Merci,
Marc
Adding a light switch in paralell off of aduplex outlet in a 2 gang box Katsry Electrical 2 11-02-2011 08:56 PM
help with wiring ceiling fan from a switch controlled outlet teamster807 Electrical 39 10-27-2011 04:09 PM
Outlet controlled by light switch billvasko Electrical 3 12-29-2009 05:57 PM
new light and switch problem please help rebelbull Electrical 1 10-02-2009 06:39 AM
Help with outlet controlled by switch craigpall Electrical 2 05-18-2008 08:08 AM
