Outlet Contact With Box Changes Test Reading - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 09-07-2012, 06:32 PM   #16
Rewards Points: 1,300
What type of wire do you have feeding this circuit? BX, NM, ETC? Also, post a picture of the load center. I suspect maybe old Knob/Tube wiring that someone hacked into. These are tough to determine hot/neutral.
danpik is offline   Reply With Quote
Old 09-07-2012, 09:13 PM   #17
Rewards Points: 664
This circuit starts out in the main circuit breaker as an old two wire cable without ground. I did not notice till today that the new wire used in these outlets does have a ground wire . Downstairs on a three way switch some idiot attached that ground wire to the black hotscrew on the switch. One thing I did learn from this is that there was indeed a reason my wand went crazy in that room. The boxes were obviously all hot so it immediately sounded when it came within an inch of a box. Thanks all for the help. The outlets now all test fine and to find if the outlet is hot I have to put the wand all the way in the slot to get a reading.
crescere is offline   Reply With Quote
The Following User Says Thank You to crescere For This Useful Post:
bbo (09-08-2012)
small secondary countertop outlet issue rasz Electrical 8 11-07-2011 04:14 PM
Outlet not working, reading "open ground" syren Electrical 3 04-19-2010 04:20 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
