Outlet Coming From Hvac Unit On Top Of Roof... - Electrical - DIY Chatroom Home Improvement Forum
Old 01-16-2013, 08:25 PM   #1
Outlet coming from hvac unit on top of roof...
I was up on roof today where the 17 year old AC unit sits atop and noticed a 110 outlet coming off it and connected to the siding. Haven't tested it to see if it works yet.
Any know why this outlet would be here? Is it code? And if it works should I use it? Because I really could use it to power a fountain and some outdoor lighting...
Freakaloin is offline   Reply With Quote
Old 01-16-2013, 08:32 PM   #2
Child Alert! Pull Up!
fltdek's Avatar
usually for the technicians servicing the unit
fltdek is offline   Reply With Quote
Old 01-16-2013, 08:43 PM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Its required by code.
Old 01-17-2013, 12:55 PM   #4
Semi-Pro Electro-Geek
Rewards Points: 2,942
It should be fine to use for whatever you want. A fountain on the roof???
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Why HVAC people want to replace unit and not coil? pcumming HVAC 4 05-21-2011 09:57 PM
Old A/C blew, time for a new HVAC unit tburk HVAC 12 09-21-2010 09:25 AM
HVAC Unit Leaking Water timb10594 HVAC 1 08-26-2009 09:51 AM
propane smell coming out of new unit jlachey HVAC 3 04-08-2008 11:12 PM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
