Outlet Causes Breaker To Trip When Something Is Plugged Into It. - Electrical - DIY Chatroom Home Improvement Forum
Old 08-10-2011, 06:42 PM   #1
Outlet causes breaker to trip when something is plugged into it.
Every time I try to use this one outlet it trips the breaker I can't seem to figure out why. When I reset the breaker as long as nothing is plugged into that outlet it will reset fine but the ground fault indicator light comes on for a second. Please help
yama450yfz is offline   Reply With Quote
Old 08-10-2011, 07:05 PM   #2
Rewards Points: 1,512
Probably some wires touching in back.
Does the breaker trip if you press the outlet with your thumb without plugging anything in?
Does the breaker trip if you plug a different item in?
Does a breaker trip if you use another outlet (receptacle) for the item you are plugging in?
Is it a regular breaker or a GFCI breaker that is tripping?
Old 08-10-2011, 07:06 PM   #3
Master Electrician
Rewards Points: 3,870
Are you talking about a circuit breaker or a GFCI receptacle?
brric is online now   Reply With Quote
Old 08-10-2011, 07:06 PM   #4
Rewards Points: 6,652
So it is a GFCI, I would try plugging what is causing it to trip into another outlet, and see if that item causes the breaker on that outlet to trip. Same with testing those devices tripping said gfci, into another gfci to see if it is either the devices, or the gfci that is tripping is bad.
Old 08-11-2011, 06:42 AM   #5
Rewards Points: 1,216
Replace the GFCI their cheap.
COLDIRON is offline   Reply With Quote
Half of double plug outlet blows breaker sjt Electrical 4 05-20-2011 03:02 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 06:42 PM
GFCI Breaker & GFCI Outlet together??? abinpa General DIY Discussions 6 04-12-2009 08:59 PM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 08:38 AM
Circuit BReaker Question - breaker didn't trip and no power thru the circuit Ronin_67 Electrical 2 08-08-2008 06:06 AM
