Outlet Boxes As Junctions? - Electrical - DIY Chatroom Home Improvement Forum
Old 02-25-2012, 08:27 AM   #1
Outlet boxes as junctions?
I want to move two outlets, that are currently at a normal "low" height on the wall, maybe 18", to up and behind my flatscreen tvs. About 5' from the floor.
Is it acceptable, by code, to install a new outlet box in the new location and use the existing box as a point to splice and run the wires up to the new box?
kbrookst is offline   Reply With Quote
Old 02-25-2012, 08:31 AM   #2
Remodeling Contractor
yes as long as the box fill (number and size of wires) do not exceed the amount for the box.
Old 02-25-2012, 09:20 AM   #3
Electrician
Rewards Points: 760
and the old box neads to be left accesible, either put a blank cover on it or leave the exisiting plug there.
darren is offline   Reply With Quote
Old 02-25-2012, 09:26 AM   #4
Licensed electrician
Rewards Points: 996
If you have the box capacity that others mentioned, just run one cable up to the new location. The splices will be in the old box. Think of this as a T.
Swithced Outlet to Ceiling Light/Fan Troubles adamiano86 Electrical 7 01-29-2012 10:36 PM
Changing 2 way switch to control light, not outlet? andysam Electrical 0 05-30-2011 10:20 PM
Outlet not working, reading "open ground" syren Electrical 3 04-19-2010 05:20 PM
Need to sink existing outlet boxes for new backsplash Stcrosby Electrical 14 02-08-2010 08:31 PM
Adding additional outlet. Pigtail four sets of wires? svanhess Electrical 5 07-12-2009 11:27 PM
