Outlet Boxes Extend Beyond Drywall - Electrical - DIY Chatroom Home Improvement Forum
Old 05-16-2010, 01:00 PM   #1
Outlet boxes extend beyond drywall
Hi All -
My contractor had to re-adjust the outlet boxes set by the electrician because he did not allow for the 1/2" drywall. but then the contractor set a couple of them too far out and they extend beyond the drywall. he said the electrician would be able to adjust them. These boxes - or something involved in the boxes - are nailed to the studs. Any thoughts, advice, how-to-fix would be greatly appreciated. Thanks!
JPFdiy is offline   Reply With Quote
Old 05-16-2010, 01:25 PM   #2
Journeyman Wireman
Rewards Points: 150
If the electrician really didn't account for the depth of drywall, they should be the one to fix the problem. The GC should have called them back to make the adjustments.
If the boxes are sitting "proud" of the wall, they will have to be removed and replaced. Removing the boxes means prying the nails out of the studs and letting them drop into the wall. Or you could cut the nails with a sawzall or hacksaw blade. Then install a remodel box. Use a "Smart Box" which has internal screws that can be driven into the studs. Here is an example:
http://www.licensedelectrician.com/Store/SmartBox.htm
Jupe Blue is offline   Reply With Quote
Old 05-16-2010, 01:38 PM   #3
Thanks for the quick reply. The drywall is up and patched and all that. How big of a deal will it be for the electrician to replace those boxes? I[m not even sure how he will be able to get to those nails. Thanks for the help.
Old 05-16-2010, 02:14 PM   #4
Master Electrician
Rewards Points: 3,678
If they are plastic boxes and not too far out 1/8" or so they could be ground down with a circular sander or another device. The GC should never have messed with the electrical work in the first place.
brric is online now   Reply With Quote
Old 05-16-2010, 02:20 PM   #5
ok, thank you.
Old 05-16-2010, 03:18 PM   #6
Journeyman Wireman
Rewards Points: 150
Removing nailed on boxes in a finished wall is a fairly common task for a residential electrician. They should be able to do it without damage to the walls. Are we talking a few boxes or a whole house of boxes? Regardless, it is the responsibility of the GC and the electrician to solve the problem.
Old 05-16-2010, 03:19 PM   #7
Journeyman Wireman
Rewards Points: 150
I would be concerned about damage to the drywall with this method. Also, you could damage the screw holes in the box making it hard to install devices.
Old 05-16-2010, 04:35 PM   #8
You can't move the wall.
4"x8" Masonite trim plates that taper down to zero would be hard to make and look weird.
Grinding the boxes is tricky.
This installation does not show "Due Diligence" or "Duty of Care" which is what people paid to do this kind of stuff are supposed to exhibit.
What a mess.
Old 05-16-2010, 05:15 PM   #9
Master Electrician
Whatever. I've done it dozens of times.
Old 05-16-2010, 09:54 PM   #10
I'm just a DIY homeowner with little practical experience, but I didn't have much trouble removing a single gang (cut the nails with a metal keyhole saw) and then widen the hole in replace it with a remodel double gang.
HooKooDooKu is offline   Reply With Quote
Old 05-16-2010, 10:21 PM   #11
Journeyman Wireman
Rewards Points: 150
I hope I didn't imply you needed to be an electrician to replace a box. Just that the electrician who originally roughed in the job should be the one to correct the problem.
Old 05-17-2010, 09:45 AM   #12
I didn't take it that way... actually I'm the one who did a poor job at trying to relay my thoughts/intensions.
What I really ment to do was SUPPORT what you were saying (that it's easy) in response to the question...
How big of a deal will it be for the electrician to replace those boxes? I'm not even sure how he will be able to get to those nails.
So I should have included that quote in my post as well.
Old 05-17-2010, 10:09 AM   #13
I've had someone hit them with the belt sander before.
Sparky8370 is offline   Reply With Quote
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 04:36 PM
Problem Patching Large Drywall Hole FuLLTiLT Drywall & Plaster 5 11-21-2009 10:42 PM
drywall repair next to an outlet - advice needed... myke232 Drywall & Plaster 2 08-19-2009 01:25 PM
wiring outlet boxes, steel or plastic? DangerMouse Electrical 17 07-20-2008 01:05 PM
replacing vanity light...issue with outlet box? tarheelblue Electrical 5 01-28-2008 10:20 AM
