Outlet Box In Wood Paneling - Electrical - DIY Chatroom Home Improvement Forum
Old 05-31-2012, 05:01 PM   #1
outlet box in wood paneling
I'm renovating a 53 year old house and found lots of electrical issues, but I'm now trying to resolve this issue.
The bathroom drywall was in such bad shape we installed bead board paneling over top of it. We installed the paneling, sink, toilet, etc and were ready to tackle replacing the current outlet with a GFCI outlet. So when I removed the current outlet I realized that the old outlet box was a retrofit that was just screwed to the drywall and had already broke drywall on the top. I figured I would just replace the box with a plastic "old work" box, but the hole is now too long (top to bottom) with the broken drywall to be able to get the clips to grab hold on both the top and bottom of the box. I can't patch the drywall since I now have bead board on top and that hole is slightly too long as well. All I really need is some type of support for either the top or bottom of the outlet box. Any suggestions?
I also discovered the oulet was stubbed off the light fixture so I guess I'll be running a new 20 amp circuit to meet code.
Etch88 is offline   Reply With Quote
Old 05-31-2012, 06:52 PM   #2
Rewards Points: 6,652
Use "Smart" boxes for the electrical work. They attach to the studs via the screws inside the box. Otherwise you have to fix the drywall before putting in the new boxes.
Old 05-31-2012, 07:09 PM   #3
Rewards Points: 13,274
Look for one of these.
http://www.electriciansupplies.com/p...-7010-8-SQ.htm
Old 05-31-2012, 07:23 PM   #4
The stud is 9" from the opening which would put the outlet over the toilet.
Old 05-31-2012, 07:39 PM   #5
Sparky
Rewards Points: 510
you could try a metal old work box and 'f-clips' or 'madison bars' or 'switch box supports'
Techy is offline   Reply With Quote
Old 06-05-2012, 04:52 PM   #6
Thanks for all of the suggestions. I decided to cut a new hole and move the outlet since I have to run a new circuit anyway. The hole will be covered by a mirror.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Removing wood paneling in one piece? dragontrouble9 Remodeling 3 04-22-2012 01:22 PM
Wood Paneling matt151617 Drywall & Plaster 7 09-13-2011 04:08 PM
wood paneling amandacarlson Interior Decorating 0 10-04-2010 02:03 AM
Wood Paneling Makeover mnjordan Painting 6 09-27-2009 08:29 AM
