Is Outlet Box Required For Vanity Light Install? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-04-2010, 10:20 AM   #1
Is outlet box required for vanity light install?
I want to install a new light fixture in the bathroom but once I pulled off the old fixture I see that an outlet box was not put in. The electrical was just pulled through the wall. Additionally, there is a drain pipe/vent running up the wall in the same spot. My question is whether the outlet box is required and if so, how I would install it if there is a pipe in the center?? Any help is much appreciated.
Jim
jmccask is offline   Reply With Quote
Old 12-04-2010, 10:32 AM   #2
Electrical Contractor
kbsparky's Avatar
SOME fixtures can be installed without an outlet box, provided there is enough space within the fixture to accommodate the required romex connector in the back.
IF you really need a box, one solution I have seen was using a shallow "pancake" or "dish pan" type box, and tie-wrap it directly to the vent pipe. Not exactly kosher, but sometimes unavoidable. The box is the same depth as the wallboard.
-KB
Old 12-04-2010, 06:57 PM   #3
joed's Avatar
Rewards Points: 12,926
Depends on the fixture. If the fixture has a box that can accept a clamp then no box is required.
Old 12-04-2010, 09:49 PM   #4
Do not attach the pan box to the vent. The weight of the fixture is supported by the box. That pan box is designed to be secured to the stud on the surface where your drywall is secured. If there is no stud right there you will need to get a piece of 2x4 and secure it between the 2 closest studs.
As for requiring a box. If the fixture does not have an enclosed termination box then you do require a box.
I hope this helps,
Kyle
Sparkitus is offline   Reply With Quote
Old 12-05-2010, 07:35 PM   #5
Thank you to everyone for your help. I appreciate it! This should get me through it.
Want to install light Petrafire Electrical 8 08-24-2010 06:23 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Adding Ceiling Light From Switched Outlet vboz5 General DIY Discussions 2 03-04-2009 12:53 PM
Converting wall outlet to power ceiling light? VEIK Electrical 3 07-08-2008 08:43 AM
Breaker for Spot light and outlet receptical hgiljr Electrical 4 08-16-2007 01:10 PM
