Outlet Box Outside Of Wall? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-28-2012, 12:03 PM   #1
Rewards Points: 14
Outlet box outside of wall?
Hi All,
I've seen in many restaurants/commercial buildings electric outlets which are mounted directly on the exterior of a wall, with the piping on the exterior of the wall as well.
Is this allowed in residential applications? In my case I would have the actual EMT pipe mounted directly on the dry wall and the switch box on the drywall as well. It will be hidden behind a corner TV unit, so I am not worried about appearance and it would be much easier to use this approach then to break open the dry wall, drill a hole down through the bottom wall plate and pull the pipe through from the crawl space below.
I have attached a couple pictures as an example of what I have seen.
tommy83 is offline   Reply With Quote
Old 11-28-2012, 12:06 PM   #2
Licensed electrician
Rewards Points: 1,892
You can use surface mounted conduit or raceway in a residential setting.
Two Switches, an outdoor light, and a wall plug MichaelT Electrical 1 03-06-2011 05:17 PM
Code requirements for outlet placement WillK Electrical 8 11-30-2010 08:16 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Range outlet pushes oven too far from wall givemeabreak Electrical 8 08-19-2008 12:14 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
